Codes 2A94 and 3100 This Morning
04-30-2014, 07:23 AM | #1 |
Rep 3,625
I was cruising at about 50 in 4th gear this morning on my way to work when all of a sudden I get a reduced power warning. I check the code with my Cobb AP and 2A94 (Crankshaft sensor, signal missing) and 3100 popped up.
The car was stuck in gear and wouldn't change to D from M mode. I came to a light, cleared the code and the 2A94 went away but the 3100 remains. Car drove fine but I didn't try to get on it at all. Any thoughts on what's causing these codes? First thing that comes to mind is the obvious which is a bad crankshaft sensor. |
06-09-2014, 09:47 PM | #4 |
Rep 120
I got the same codes yesterday....ordered new sensor...not fun.
2013 BMW M5 - B&O Sound - Piano Black trim - 2 toned grey/black interior.
2016 M3 - Fully Loaded - GF's car Grave Yard - 2014 BMW 640i - 2007 BMW 335i - 2006 BMW M5 - 2003 Infinti G35 - 2002 BMW 740i - 2002 CBR 954r - 2000 BMW 540i - 2000 BMW 328i |
08-13-2014, 03:11 PM | #5 |
Rep 1,176
Just had this happen to me. I got a transmission fault message as well as a reduced power engine malfunction message in iDrive. I was able to clear the 2A94 code right away. After turning the car off and locking it for a few minutes I was able to clear the 3100 code. Car seems fine now.
@JStang Where did you get the crankshaft sensor and did you install it yourself or take it somewhere?
335i Coupe, JB4 (G4, map 5) DCI and 40% E85 blend: 2009 BMW 335i Coupe: 12.173 @ 109.490 MPH
08-13-2014, 08:31 PM | #6 | |
Rep 3,625
08-13-2014, 08:33 PM | #7 |
Rep 1,176
Thanks for the reply, bud. I found a DIY and it looks pretty simple so I'll just order the part and replace it if it comes back.
08-14-2014, 09:03 AM | #8 |
Rep 1,176
You were right. Happened again this morning while driving to work. The iDrive went nuts with error messages. I ordered a new sensor and hope it gets here sooner than the shipping estimate.
11-20-2014, 08:43 AM | #9 |
Rep 2
Crankshaft sensor did the trick. Thanks! Just a tip, don't try to pull the sensor from the bottom, it's to hard to get the right angle.
