E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Has the time finally come where we can do away with Direct Injection?
      04-29-2014, 07:04 PM   #1
SINGH_
N54 E92
SINGH_'s Avatar
51
Drives: 2009 BMW 335i
PTF Presents...
Light Bolt-ons, Tunes, & Methanol Injection:
12.30 @ 115mph [2.0 60ft on Street Tires] [91 Octane]
1.59 Seconds Faster than Stock [as of 05/29/2014]
Previous Vehicle: '65 Chevelle [LSx 6.0L/4L80e]
      04-29-2014, 08:17 PM   #2
ksalih
ksalih's Avatar
Drives: 2018 M2 LCI
Don't flame me, but why would we want to do away with DI? What are the downfalls with such? And benefits with the proposed setup above?
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
      04-29-2014, 08:22 PM   #3
135Pats
135Pats's Avatar
Drives: A few BMWs
Moar fuel, that's the only reason. DI is more efficient, burns cooler and better, you can lean it out, numerous benefits. But the injection window is tight, and the fuel pressures reqd. are gnarly. So supplemental port should solve that, and from there it's largely just up to the size of the turbo and tuning. We'll see when the motor lets go, which we don't know yet. I'll guess much north of 700 you'll start losing pistons.
For me I want to spray meth via a port plate like this. I took my kit off not long ago and don't plan to use it again if spraying via the chargepipe or IC is the only means.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII
      04-29-2014, 08:38 PM   #4
gtaccord
Drives: 2009 BMW 335xi
Not really a replacement for but a supplement for direct injection.
      04-29-2014, 08:43 PM   #5
peter91118
peter91118's Avatar
29
Drives: '01 325xit, '09 335i
No more walnut blasting!
      04-29-2014, 08:46 PM   #6
Jed
IN THE KNOW!!!!!!!
Jed's Avatar
Drives: 1994 E36 325is; 2007 E92 335i
Yeah, I'd want it just for the valve cleaning!
2007 Jet Black 335i Coupe: Saddle Brown interior | ZSP | ZCP | ZPP | iPod integration.
1994 Hellrot 325is: Sport Package | PSS9 Coilover | AutoThority chip | AutoThority CF Intake | UUC pullies | Dinan HiFlo Throttle Body | UUC StrutBarbarian | UUC Evo II SSK | BMW Motorsports X Brace | Rogue Engineering DMS exhaust | Kumho Ecsta V700 R Comps |
      04-29-2014, 09:30 PM   #7
Jeef
Drives: AW E92 335i
The wait for this is killer.
      04-29-2014, 10:59 PM   #8
shmorgan77
shmorgan77's Avatar
Drives: BMW 135i
I knowww this sucks 😟
      04-29-2014, 11:08 PM   #9
Allen@MOTIV
38
Drives: 135i
This will not replace the factory DI. It will run along side it and be used to provide the fuel necessary for big horsepower cars or to help those wanting to run E85 or any other number of uses.
Good things are coming guys
      04-30-2014, 12:40 AM   #10
flinchy
Drives: E82 135i
wonder what PTF is going to work out to control it
looks stunning though
      04-30-2014, 12:43 AM   #11
tc535i
Drives: 2007 335i, 2001 330i, 1995 M3
Can meth be run "wet" like nitrous?
      04-30-2014, 12:43 AM   #12
flinchy
Drives: E82 135i
meth IS wet.. it's fuel, not oxygen.
      04-30-2014, 12:48 AM   #13
tc535i
Gotcha. Would this be an effective port injection meth plate? Would spray injectors to help avoid deposits etc
      04-30-2014, 12:59 AM   #14
WedgePerformance
BimmerPost Supporting Vendor
WedgePerformance's Avatar
Drives: Slot Machines.. Keep Taking $
haha like a automatic car was for your intake valves. hehehe
Nice work guys. HPF tried this and failed big time, but then again, after they got the e46 right by outsourcing everything to make it work, they couldn't design their way out of a wet paper sack.
      04-30-2014, 01:01 AM   #15
WedgePerformance
Allen, why don't you post up the new intake manifold and throttle body also? Please... Car porn is the best.
      04-30-2014, 01:06 AM   #16
BigBoss
Drives: 335i or 535i
Looks awesome
      04-30-2014, 01:10 AM   #17
WedgePerformance
I need my own 3D printer so I can make my own BMW parts like HPF.
BTW - Sorry for the HPF bashing... I'm just happy that PTF has picked up the pace and is not turner their backs on the N54/N55 community.
      04-30-2014, 02:12 AM   #18
Sfvalley135i
Drives: 135i
not PTF but others have been working on a solution...
      05-01-2014, 11:41 PM   #19
listed5
Drives: 2011 e93 M3 DCT black/bamboo
Those injectors don't even look angled!
      05-02-2014, 12:12 AM   #20
N3m3sis
Drives: 335i
Its funny following this since we were doing this with mazdaspeeds roughly 4/5 months ago.
Will we be running this off of a split second tuner, and running a secondary tank, or are you guys working on something to Y off of using a bigger pump and factory tank?
      05-02-2014, 01:00 AM   #21
BOOST3D
BOOST3D's Avatar
Armenia
30
Drives: 328i 2000,X5 2003,2008 335i
Vargas has a HPFP upgrade coming out and the injectors on this car are rated at over 2000cc, so I don't know if secondary injection is going to be worth the money and time when you can just upgrade the HPFP and the low pressure pump without having to worry about all the extras needed with secondary port injection
      05-02-2014, 01:25 AM   #22
Sfvalley135i
Drives: 135i
Have you seen pictures of what the vargas hpfp upgrade looks like? Its actually a secondary HPFP in addition to the one that you already have.
e90post
