E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Spec 2+ clutch + SM flywheel installed.. questions now.
      04-29-2014, 04:34 PM   #1
drfrink24
Drives: 2008 335xi
Its been 600+ mixed driving miles since my clutch install on my 335XI. Pedal feel is stiff, but fine. Since I'm past the break-in period, I've had one or two full WOT pulls and it seems to be holding fine.
One concern is the shudder/shaking on take-off. Since I've never had an aftermarket clutch, I have zero frame of reference. I simply cannot smoothly take off from a stop. I've been driving manual transmission cars exclusively since 1993, and for the life of me, the car shudders/shakes pretty bad on take-off. Raising the RPMs helps, and its butter smooth once moving, but man...
My twin 3yr old boys ask me why our driveway got so bumpy!
Is this normal for a spec 2+ w/their SM flywheel?
Also, sidenote... Dealer (getting coolant flushed) just called and said the car is moving when the clutch is pressed in? I have not experienced that at all, hoping their tech just isn't pushing the clutch in all the way??
      04-29-2014, 04:41 PM   #2
stanlalee
Drives: 07' E92 335i manual
Between the segmented side of the disc (one side only) and SMFW conversion yes normal. You'll learn to drive it smoother/should lessen some with a lil more usage. I don't have a 335 SPEC 2+ clutch but I've had a SPEC 2+ and several other segmented and SMF conversions. They can be annoying for stop and go driving.
      04-29-2014, 05:02 PM   #3
oshusttoley
Drives: 2008 335i sedan
Just got the spec stage 2+ with steel smfw. Car will be on the road tomororw and will let you know if I experience the same results you are getting from a stop
      04-29-2014, 06:10 PM   #4
nikitino25
nikitino25's Avatar
Drives: '07 E92 335i
Do you have your clutch delay valve removed? If not, removing that would surely help.
      04-29-2014, 06:11 PM   #5
oshusttoley
Is your rattle bad? Just got my car back and my rattle is horrible! Even driving at 30mph you can hear it horribly!!! When foot on clutch all the noise goes away. When clutch is out, the rattle and grinding noise is terrible! Sounds like a broken diesel truck. Is this normal for break in period?
      04-29-2014, 07:33 PM   #6
rdeterman
rdeterman's Avatar
11
Drives: 2008 335i Coupe 6mt
my car is the same way. I have about 5000miles on the clutch now and its still grabby. I like it because I know its doing its job. I also have the CDV delete done. Just something to get used to
JB4 G5 ISO W/BMS FLASH, FBO, Walbro LPFP, Spec S2+ SMFW
      04-29-2014, 09:00 PM   #7
psmitty95
psmitty95's Avatar
Drives: '23 M340i xDrive
Pretty sure it's normal. I have the 3+ and it's tough to be smooth from a stop but i've found the best way is to rev it to 1500 then let the clutch out at a good pace. Don't drop it but don't try slipping it either. It grabs hard so it doesn't like the back and forth slipping it likes to be either going or not
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion
Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning
More Pictures: Build Thread /// 683AWHP/675AWTQ
      04-30-2014, 10:37 AM   #8
drfrink24
Drives: 2008 335xi
It is normal, however, good news:
http://store.uucmotorwerks.com/artic...uce_rattle.htm
I had my transmission oil changed per that formula listed, and I have only the slightest (nearly inaudible) rattle.
The only downside is shifting is a bit notchy and getting into 1st and reverse is harder from a stop.
In fact, I haven't heard any gear rattle since the first day of the install.
      04-30-2014, 10:38 AM   #9
drfrink24
Drives: 2008 335xi
I have the CDV removed. I'm getting used to it now, it actually has gotten better the last 200 miles or so.
e90post
