Need more Ponies!...and advice!
04-29-2014, 01:03 PM | #1 |
Rep 1,076
Drives: 07 335i e93 6MT
Hey guys, so I need some advice. When I bought my car, I specifically looked for one that has the PPK v2 as I told myself that I wasn't going to mod my car anymore and just work on cosmetics. I was lying to myself. After 10 months of ownership I have now got the performance bug and want...nay...need more POWER!!! lol
I read a bunch of reviews on here of different products but wanted to get your input on how I should go about it. Also, I'm wondering because I have PPK if it will get in the way of other mods (will a tune just override the ppk tune? also if I do decide to go back, will it revert back to the ppk tune?). I'd like to retain as much of the PPK as possible. I plan on going FBO, then a tune (JB4 or Cobb). With the FBO, what order should I attack this? I do really miss the sound of turbo spool so thinking of intake first. From what I read it seems that BMS, AFE, etc. are all pretty similar in gains/hold. correct me if I'm wrong. Then CP (are they all pretty much the same? ER seems to be popular here), forged dv (or maybe throw in a BOV in there) actually probably do this together with intake since it's exposed anyways. Then FMIC. Haven't decided which yet. Opinions welcome. DP...this is where I'm a bit confused, does the PE exhaust have an upgraded DP? Couldn't find info on this. I have to replace my tstat and wp soon so depending on if I need a new dp, then might just do this all together while under the car. Next question, it seems that with fbo and tune on pump gas people are getting around 350-360ish whp. Does that sound about right? To get over that 400 mark do we need to upgrade turbos? Appreciate any help. Thanks.
07 BMW 335i E93 6MT (Praying neighborhood doesn't get flooded...again) 04 Infiniti G35 Coupe 6MT (Flooded) 08 Audi TT 2.0T DSG (Flooded) 03 Subaru WRX 5MT (Flooded) |
04-29-2014, 01:08 PM | #4 |
Rep 913
no exhaust systems that I know of include down pipes. PE definitely does not. They are a separate purchase.
Depending on dyno you can be at 400whp with 93 octane gas and fbo. See my sig. Once you go down pipe you are going to need a tune right away to prevent the o2 codes that will get thrown with a dp. I personally prefer a tune (cobb) vs. piggyback (jb4). Lot's of opinions on this, do your research and make a decision. Can't really go wrong either way. |
04-29-2014, 01:11 PM | #5 |
Rep 1,076
That sucks!
to the wheel?! that seems high.Plus I read that you need to play around with the tun to run e85 right. Could be disastrous. I could have read it wrong. Plus I don't know anywhere around me that has e85.
04-29-2014, 01:13 PM | #6 | |
Rep 1,076
04-29-2014, 01:15 PM | #7 | |
Rep 913
Every dyno reads different. While it is fun to throw out dyno numbers, they are a tuning tool. trap speed is what will tell you what you are really making. Too bad the track by my place shut down right around the time I got my car. |
04-29-2014, 01:16 PM | #8 |
Rep 1,818
tune on an otherwise stock car turns the boost up 4-6psi and nets you an easy 50-60 hp or so, best bang for the buck out there when you consider all the other benefits of units like JB4 (gauge jacking for psi/IAT/etc, code reading ability, USB datalogging, etc)
04-29-2014, 01:17 PM | #9 |
Rep 913
04-29-2014, 01:23 PM | #11 | |
Rep 1,076
04-29-2014, 01:25 PM | #12 |
Rep 1,818
04-29-2014, 01:31 PM | #13 |
Rep 1,076
Interesting...but what' the fun in that? lol. Appreciate the help btw.
04-29-2014, 01:33 PM | #14 | |
Rep 913
I am not sure with cobb. I know if you were to have a non-bmw tune on your car beforehand the cobb does not save that tune and will install a base tune if you unmarry it. Not sure if ppk is treated differently and saved. I'd get in touch with cobb on that one. |
