Tire Size Question
04-28-2014, 07:31 PM | #1 |
Rep 1,126
Tire Size Question
I have an XI, and I'm a little confused about the offset/1% difference discussion. I just need someone to confirm my suspicion here.
I found a set of new wheels/tires and the dimensions are 225/45/17 front, 255/45/17 rear. The calculator is telling me (if correct) that this is a 4% difference, in which case I should NOT put these on my XI. Is this correct? Thank you! |
04-28-2014, 07:50 PM | #2 |
Rep 109
Drives: 2007 E90 335xi
Correct.
04-28-2014, 10:58 PM | #3 |
Rep 1,126
What if I put spacers in the front? Would that make a difference?
I'm sorry I'm uneducated on this topic, but I'm trying to get my head wrapped around it. Thanks for your help! |
04-28-2014, 11:08 PM | #4 |
Rep 1,126
Whoops... Just realized I received the wrong tire specs. They are actually 225/45/17 front and 255/40/17 in back. It looks like he is .2% difference. Is that correct? What would happen if I put 20mm spacers on the rear? I don't think that would affect it because I am under the impression only diameter is the concern, not width. Correct?
04-29-2014, 04:45 AM | #5 |
Rep 109
Those specs will be fine. Offset doesn't matter.
04-29-2014, 08:43 AM | #7 |
Rep 208
you should be fine. mine came with those tires stock from bmw.
2008 E90 328 X-drive -KW V1- Auto-Sport-Blacklines-LED interior lighting
Summer: Style 195 F-225/40/18 R-255/35/18 on Bridgestone RE760 Sport Winter: Style 161 - Sottozero RFT 225/45/17 square |
04-30-2014, 09:43 PM | #9 |
Rep 1,126
05-01-2014, 12:11 AM | #10 |
Rep 167
Correct. Rolling diameter is the only thing thats important. Offset just changes how far the wheel/tires stick out among other things,but that doesnt interfere with the AWD system. Just focus on getting that rolling diameter under 1% which you will already have with that square set up
Alpine White|Coral|e92
ZSP|ZCW|ZPP|X-Drive |
05-01-2014, 07:09 AM | #11 | |
Rep 1,126
05-01-2014, 07:50 AM | #12 |
Rep 2,387
Wait a minute, even if within 1% rolling diameter, wheel offset does matter depending on what kind of wheels they are. If they are OEM e9x you're likely fine but lot of wheels will not work due to clearance issues.
05-01-2014, 08:23 AM | #13 |
Rep 1,126
I am referring to OEM, but my main concern was the AWD system. I don't mind working with clearance issues as long as I am not tearing my AWD system up in the process.
05-01-2014, 09:10 AM | #14 |
Rep 24
2008 335xi - Staggered
I am running the following without issues for several months.
MRR GT7 18x8.5 +35 5x120 72.6 HS MRR GT7 18x9.5 +40 5x120 72.6 HS P235 40ZR18 Hankook VENTUS V12 EVO K110 95Y XL B P265 35ZR18 Hankook VENTUS V12 EVO K110 97Y XL B |
05-01-2014, 09:26 AM | #15 |
Rep 1,681
Your tire sizes should work and the systems are so sensitive that they really won't let you do much damage. It should go into limp mode if the tire sizes are way off because it thinks something is wrong.
05-02-2014, 08:44 AM | #16 |
Rep 342
Drives: E90 Monaco Blue 335i xdrive
Hey I'm really really sorry to try to jack the thread but I thought it'd be better than posting new since there are a thousand tire size questions. I'm looking at getting staggered on my xi as well. I'm looking at Apex EC-7 18x9 ET31 with 245/40/18 and 18x10 ET43 with 275/35/18. Will this work well with my car? I believe I saw it is .5%. Currently I am stock suspension but I heard I still might need slight rolling in the back. I know when I lower it later I definitely will. Thank you!
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
