E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 2007 335i misfires many parts changed ... at a loss
      04-28-2014, 04:33 PM   #1
The Kingpin
Drives: 2007 335i sedan
So i have a 2007 335i. I have an ETS intercooler, downpipes, xpipe, DCI, JB4 (not currently installed). I had been having rough idles and misfires under load. Took it into Dealer 2 weeks ago. They had it until this past friday. They checked everything - vanos, fuel pressure, compression, replaced 3 injectors, etc.
They told me they narrowed it down to O2 sensors. They changed both sensors and said it was running great.
We went for a sunday drive yesterday. Merging onto a highway and i pinned it. Engine light flashing, violent shaking, no power. Pulled over and shut off car and waited a few minutes. Turned back on, seemed normal. Pull back on to highway and pinned it again - same thing.
I have had this issue for almost a year. So far they have changed valve gasket, oil gasket, turbos, all 6 injectors (replaced 3 last week again), walnut blasting, sparkplugs are 3 months old, just had an oil change.
This last week when i took it in i said i thought it was a fuel pump issue. They said they checked and was all good. I have pulled codes before with JB4 and i get misfires on 5 of 6 cylinders and a fuel delivery sytem code.
Anyone have any clue as to what i might be missing?
Also, the misfires get worse the warmer the car gets. On a cold engine they are little blips. After driving for a bit more than a half hour yesterday was when shit went down.
      04-28-2014, 05:00 PM   #2
AtlantaDude
Just enjoying my time
AtlantaDude's Avatar
Drives: 2007 BMW E92 335i - Sold
Shit dude, this blows... You're going to need better codes than what the JB4 tells you. If you have a BT scanner, keep it in the car... You need to get the codes that pop WHEN then error occurs... Not after you've cycled the car. The fuel pumps can be ok under idle load, but failing under WOT. It sucks that you've been spark chasing this long. I've at the point of replacing my fuel injectors on my car, I still have the original OEM injectors, and other than the fuel pumps, they're the only thing that I haven't replaced... Good luck on your hunt though.
Current - 2022 Rivian R1T, 2021 Ducati Streetfighter V4S, 1969 Chevy C10
Sold - 2018 Tesla Model 3 Performance
Sold - 2007 E92 335i
If speed is death, then buy a Honda and live forever
      04-28-2014, 05:26 PM   #3
SeminoleN54
Turbo
SeminoleN54's Avatar
Drives: 335i
Sounds like coil packs.
      04-28-2014, 05:39 PM   #4
AWil335i
AWil335i's Avatar
12
Drives: 2007 E92 335i
^Exactly since you didn't mention changing them in the post. I'd think that would be one of the first things you or the dealer would change?
Also, I'd put the JB4 in and see if you can get a log of what is happening when you're getting the misfires. It may help pinpoint whether it's fuel or ignition related...
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS DPs | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
      04-28-2014, 06:10 PM   #5
pwr hungry
Drives: 335
I'd do coils and if that doesn't fix it swap the hpfp.
      04-28-2014, 09:34 PM   #6
The Kingpin
The dealer checked the coils. all were good but one. I replaced that one a few months ago.
The only thing left that i can think of is the hpfp or the lpfp.
They even did a compression test last week and it holds all the right levels.
      04-28-2014, 10:11 PM   #7
rudebwoi
Drives: 17 F82 6MT ZCP Mineral White
don't mean to thread jack but also having the same issue....
-Injectors are new replaced by BMW
-Coils have been switched all around each cylinder and even replaced, tested by bmw
-Boost test comes back OK
-Walnut blasting done
-Compression is 170 across the board with 160 on Cyl 6
- Vanos solenoids, and even bearing ledges replaced
Codes are vague, but also similar to you and also has issues at cold start. Sometimes the issue completely disappears, but under load can almost never get past 3500 RPM.
Dealer also says HPFP and LPFP are fine, I've logged and even watched it on the Cobb. I'm at a loss...
2017 F82 ZCP 6M
      04-29-2014, 06:30 AM   #8
Tzu
Drives: 335i
I dont see vacuum listed here.
      04-29-2014, 06:38 AM   #9
jayzF30
Drives: '07 335i, '09 M3
Have you done a compression or leakdown test? Personally I do not trust the dealer at all.
      04-29-2014, 06:42 AM   #10
Eat.Sleep.Race
Out Boosting...
Drives: F30 335i M-Sport
I would have got so frustrated probably would of sold the car lol... Good luck and hopefully once you get it figured out you can give the forum some insight on wha tthe next issue is.
Alpine White M-Sport F30
      04-29-2014, 11:34 AM   #11
Bluesnake01
Drives: 09 335i Sedan, 6AT
A vacum line leaking can make this happen as well. So if you changed your coils from cyl 1 to cyl 6, does it still show cyl 1 bad or does it jump to cyl 6?
2009 BMW 335i Jet Black - BMS Dual Cones, GP Thunder 7500k Fog's, Hellst XRT H8 AE, JB4 G5 ISO Map 5 -
2001 Cobra True Blue - Terminator Swap, 460WHP -
      04-29-2014, 03:43 PM   #12
The Kingpin
I called the dealer yesterday. they are taking it back in next monday. They said they were focused on rough idle and bouncing rpms.
I asked several times if they had taken it on a hard run on the highway and they said they did take it for a drive but it doesnt sound like they took it for a hard run which is when it misfires.
I still think it is a fuel delivery issue. Can onyone think of any other thing that it could be if all these other things have been addressed?
      04-29-2014, 07:47 PM   #13
Dustz
Chieftain
Dustz's Avatar
Drives: E90 N54 335i
coils
Got Boost?
2014 650xi F06 - Carbon Black
2015 640i F13 - Alpine White
2007 335i E90 JB4/HPF Gen 2 - Jet Black-Retired
      04-29-2014, 08:06 PM   #14
ksalih
ksalih's Avatar
Drives: 2018 M2 LCI
What he said, I would still bet it's coils. Switch them and see if the missfire follows the coil. Have you walnut blasted? Try one step colder plugs, they fixed my missfire issues at WOT with my mods.
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
      05-06-2014, 01:35 PM   #15
The Kingpin
So took the car back yesterday to figure it out. They scanned all the codes and found many instances of multiple misfires. They checked the coils and vanos. All were good. changed out my sparkplugs for free.
Now ill run it hard for about a week to see if we finally got it. Last night and today, so far so good. Cant wait to get the JB4 back on there.
      05-06-2014, 01:50 PM   #16
LQQKOUT
Drives: 335XI
Mine did the same thing under load and it was the VANOS solenoids.
      05-06-2014, 04:56 PM   #17
dbudh001
Drives: m4cs 2020
I have an 07 June built. I had this issue it's the HPFP failing. Haven't gone bad yet. dont forget you are tuned - Would have been great if you had a Cobb. You could monitor fuel - it Could also be the ecu. You May have blown a MOSFET or 2 on the ecu. There's an awesome write up and tons of documentation of this happening search the forum " blown ecu misfire" . What ecu is it ? Ecu for. 2007s are prone for this. & It could also be the coil packs - I mean Uve done everything else
Btw if that dealer didn't start with changing coils as their starting point they suck
Here's one of the threads
Repairing a 'fried' N54 MSD80 DME http://www.e90post.com/forums/showthread.php?t=734162" rel="ugc" target="_blank">http://<a href="http://www.e90post.c...p?t=734162</a>" rel="ugc" target="_blank">http://<a href="http://<a href="http...734162</a></a>
      05-06-2014, 05:02 PM   #18
dbudh001
Drives: m4cs 2020
Another suggestion take it to another dealer bc those guys don't sound like they know what they are doing
I went and looked for the paper work. They did and replaced the following
Walnut blasting
Ecu
Injectors bank2
Coils
HPFP
e90post
