E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Codes 2C32 and 2C6A after DP Fix install, thoughts?
      04-28-2014, 04:18 PM   #1
Envuks
Envuks's Avatar
26
Drives: '08 e92 335xi
Hi folks,
I got the following codes about a week after installing my DP fix:
2c32 - lambda probe
2c6a - after cat o2 sensors switched
My car also put out a CEL.
I've installed the DP fix previously without issue and I took my time with it this time around as well. I was thinking about opening it tonight to see if any of the wires came loose in the computer. Any other ideas? Anyone have a similar experience before?
Thanks in advance for any Ida's you may have, they're very much appreciated.
Jet black e92 6mt 335xi:
18" BBS RGRs, KW v1, ESS Stage 2 flash, VRSF 7" FMIC, VRSF downpipes, JG Mods m-tech front, mtec V3 AEs, BMS OCC, hardwired valentine 1, p3cars gauge, amber delete, sport seats, factory oil cooler.
      04-28-2014, 06:01 PM   #2
Envuks
Envuks's Avatar
26
Ok folks, here's the problem / resolution so there's a record in case anyone else experiences something similar.
When I opened up the ecu, the red male wire on the DP fix (the one that plugs into wire 23) was broken at the connection point. I had to remove the DP fix and will need to order a new one.
      04-29-2014, 09:18 AM   #3
blisstik
blisstik's Avatar
Drives: E92
Swap your o2 sensors after the DP, towards the rear.
e90post
