Stage 2+ Datalogs
04-28-2014, 01:54 PM | #1 |
Rep 2,114
Stage 2+ Datalogs
First time I've actually pulled logs since going to to Stage2+FMIC running roughly 94 octane (blend of E85 and 91). Pulled the standard 3rd gear log as well as a 60-130 log just for kicks. Still getting the hang of datalogging with the Cobb V2. Very different from the OFT.
3rd gear pull: http://datazap.me/u/alpineswift/stg2...=0&data=1-2-21 60-130 pull: http://datazap.me/u/alpineswift/60-1...=0&data=1-2-21 Every map on the Cobb has just felt rock solid compared to the OFT maps. I have noticed the boost isn't as high as it was when I was running the stock DP's (17.5psi vs 16.5-15.5psi) but my dyno this past saturday @ 391awhp and 441tq seems to prove that my car is still a beast regardless of the lower boost pressure. I think a lot of it has to do with the altitude up here. The turbos are breathing a lot easier into the ar catless dp's but they aren't really getting any extra air on the induction side either. Based on the logs, I don't really see anything that would cause concern. No knock correction and a healthy AFR seems like a win win in my book. If anyone notices something that doesn't look right, please let me know.
E92 '08 335Xi 6AT - Cobb AP3 Tuned by MAC Autosport, Original Prototype Xi DOCRace 6266 Single Turbo Swap, VRSF CP w/Synapse BOV, VRSF 7" FMIC, BMS Cowl, H&R Coilovers, Renn Motorsport RS-51's, Stoptech Stage 2 Slotted, xHP Stage 3, Earl's Racing Oil Cooler, Turner Boost Gauge, M3 Lip Spoiler.
Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; The Colorado Mile hosted by The US Mile. |
04-28-2014, 03:17 PM | #2 |
The Wolf
247
Rep 987
Drives: stuff
why'd you ditch OFT?
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
04-28-2014, 03:22 PM | #3 | |
Rep 2,114
04-28-2014, 03:31 PM | #4 |
Rep 6,478
Timing curve looks excellent and fuel is fine. Actually that timing curve is outstanding, the ethanol really helps there.
You’re overshooting pretty good on spool, which doesn’t surprise me. It’s going to be a challenge getting boost really dialed in at your altitude. If you could add TPS that would be helpful to see how the throttle plate is trimming boost once you overshoot. Maybe try pulling out a bit from the adder table down low?
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
04-28-2014, 03:36 PM | #5 | |
Rep 4,392
Actual load is between 150-160 Timing is 9° timing @ 6k RPMs Boost is 16 tappered to 11 psi @ 6k rpms I would say this looks closer 391 "crank" HP not awhp or whp, or the dynoe is readying wayy too high Last edited by BQTuning; 04-28-2014 at 03:43 PM.. |
04-28-2014, 03:40 PM | #6 | |
Rep 4,392
His actual load, boost means, and boost are not disruptive in the curves |
04-28-2014, 03:42 PM | #7 | ||
Rep 2,114
04-28-2014, 04:03 PM | #8 | |
Rep 6,478
Either way he needs to work on the overshoot. Outside of that, it’s a very sharp log.
