E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Oil level problems!
      04-28-2014, 12:11 PM   #1
jer335
Drives: 335i
Oil level problems!
Two weeks ago, BMW installed new turbos under warranty. Got the car back. There was a leak from the o-ring from the return line. Dropped car off last week to get leak fixed. Got car back on Friday. Checked oil level indicator and oil was 3/4. On Saturday oil was down to 1/4. On Sunday it was telling me +1. Added a quart. Oil was max and after driving an hour oil was down to half. I don't see or smell any oil leaking. I understand that the oil indicator fluctuates depending on the heat and condensation of the oil. However I don't know if I'm really getting accurate readings. Last oil change was about 2000 miles ago. Oil I use is Redline 5w30. Car is a 07 335i AT. Any inputs or advice on this? Thanks.
      04-28-2014, 01:34 PM   #2
BQTuning
Drives: 2012 Z4 sDrive35i M Sport 6MT
Sound like the oil level sensor , I have a similar issue, the only difference mine always shows full when it isn't
      04-28-2014, 02:59 PM   #3
peter91118
peter91118's Avatar
29
Drives: '01 325xit, '09 335i
Drain your oil and measure how much comes out. If the amount measured agrees with your sensor, then you might have issues. If you get 7 liters out, probably just a bad sensor.
e90post
