Denver Fuel Options for a Tuned Car?
04-27-2014, 07:40 PM | #1 |
Rep 236
Relocating to Denver in a few months but couldn't find any stations with 93 octane on my last trip. I've got a PTF tuned 335is running 93 and I hate to give up my map. Any stations around with 93? Really hate to go back to stock as the car performs so much better. Guess I could always go back to PTF for a 91 octane map.
2011 TiAg 335is -->2015 Range Rover Sport
04-27-2014, 07:47 PM | #3 |
Life is better with burnouts
97
Rep 611
04-27-2014, 07:52 PM | #4 |
Rep 780
04-27-2014, 07:53 PM | #5 | |
Rep 713
Good luck and welcome to Colorado! Make sure to check out the Rockies/Midwest Forum on here and join the Colorado BMW Groupė on Facebook. Pretty active groups with lots of info on the Front Range. -Rich |
04-27-2014, 08:10 PM | #6 |
Rep 1,061
Thinner air affects the speed and ability to get to max boost. You might have to be really aggressive to require higher octane unless you're on a track. I know people mix in E85, but BMW does state a maximum alcohol content. If you keep your car a long time, you may not like the end result.
04-27-2014, 09:04 PM | #7 | |
Rep 780
04-27-2014, 10:37 PM | #8 | |
Rep 574
04-28-2014, 07:03 AM | #9 |
Rep 236
Thanks for some advice. Doesn't hurt my feelings to hand a few dollars back over to PTF for another map. Great guys.
08-21-2014, 10:22 PM | #10 |
Rep 236
Big props to PTF
Big props to Jake at PTF. Touched up my previous tune a bit (over a year old) to handle the new altitude and fuel options...for free. Not pulling as hard as it used to but I've now got some kick back. No customer service complaints here!
08-21-2014, 11:36 PM | #11 | |
Rep 713
-Rich |
08-22-2014, 12:00 AM | #12 |
Rep 2,189
08-22-2014, 01:54 PM | #13 |
Rep 166
Yea best bet is to just run an E30 or more mix and the respective tune.
You can get 101 octane from a couple of stations in town, but it really depends on where you live and that stuff is about 7 bucks a gallon. If you end up living on the north side of town its much harder to get 93 or 101 but e85 is cake. So like we've said, an e85 mix is your best bet. I've also noticed with the altitude that your intake temps (not just the charge air temps, but the actual air coming in to the compressor on the turbo) are very important to keep boost. With a BMS DCI I was having trouble on hot days hitting 16 PSI, then I put a heat reflector blanket in and keep the ambient temp next to the DCI down under 110 deg F most of the time and it does MUCH better, peaking around 17.8 on a good day (though that's not consistent). The DME does actually compensate for altitude based on the barro sensor. Your peak boost requested will be reduced from mean abs of about 31 or so to mid 28 or so on the cobb E30 map in my experience. There is also at least a 1/4 second increased delay in turbo spool up below 3000 RPM... The FMIC also doesnt do as good a job cooling so you'll see higher charge air temps as well.... just the nature of the beast. Might be a good idea to check your turbo solenoids and vacuum lines as to get to maintain boost you'll be keeping your waste gates closed more as well. Hey, at least its not NA right?! |
08-22-2014, 07:15 PM | #14 |
Rep 236
@richpike... Can't complain about Denver. Lifestyle is worth a few HP. I'll check out the Facebook page. Thanks.
@shush... Really noticed the lag and the power drop under 3k. Seems to run pretty solid now for both daily and spirited driving though now. But as you said, I really notice the power loss more in my NA Titan...especially up top. Goes with the territory I guess. One more reason to look at a bigger single turbo setup down the road.
08-24-2014, 09:20 PM | #15 |
Rep 1,061
If you happen to believe the multi-billion dollar company and their numerous engineers, one would think they know their engines better than the average guy off the street. They list the max amount of alcohol for a reason. Should you choose to use more, yes, you'll get higher octane and with reprogramming, more power output, but if you keep your car a long time, you may not like the end result.
08-24-2014, 09:27 PM | #16 | |
Rep 1,093
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
08-25-2014, 01:54 AM | #17 |
Rep 334
I was pro tuned for 91 when I was in the CO area for a year but not back to 1000ft altitude its time for a revision and hopefully a little more oomph.
COBB|PTF PROTUNE|VRSF 5" IC|VRSF DP|DMS DCI|KW v2|HUPER OPTIKS|VALENTINE1|AKEBONO|ZIMMERMAN
