N54 lumpy idle long cranks
04-27-2014, 01:54 PM | #1 |
Rep 29
Hello to you all.
I recently bought a 2008 335i It had 52k on the clock, full service ect... Anyway not long after I bought it the car went into limp mode, had it diagnosed and changed the vanos solenoids, which solved that issue. Now I am on 57k and for a few thousand miles I've had a lumpy idle, long cranks worse when cold, however when warm still idle shake. Doesn't throw any codes, I changed oil and plugs, to no avail, however when removing the old plugs, only done 10k, cylinder 1 and 5 were highly contaminated with what I think is fuel. Would I be right in saying I have two bad injectors? Leaking into cylinders causing a long crank? As I am in the uk bmw want to charge me 200 gbp each injector, so does anyone import them to uk I could get some cheaper. Any advice is really appreciated thanks. |
04-27-2014, 05:23 PM | #3 |
Rep 2,872
My idle also has a slight "sputter/lump", if you will. I'd be curious if other have this issue as well.
My guess is carbon build-up being the culprit.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
04-27-2014, 07:32 PM | #4 |
Rep 554
Drives: E92 335i 6MT
It's likely your injectors, I have the same issue with a brand new HPFP, LPF sensor, plugs and coils too. My #2 cyl plug was black, and smelled like gas so I'm assuming it's leaking.
04-28-2014, 01:17 PM | #5 |
Rep 29
Does anywhere sell and supply to uk? I'm gonna try changing the bank, sure this is my problem I know a lot have hpfp and carbon build up but my plugs are covered in fuel so sure mine are just bad injectors. Any more help welcome
