E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > misfire only with tune...is that normal?
      04-26-2014, 10:07 PM   #1
parabmw
Drives: 2018 m4
I got thr p29cd misfire cyl 1.
I change the cyl1 plug and switched ign coil to cyl2 to see if coil was bad.
I noticed some oil in plug sleeve and on ign coil for 2 cyl.
so now I got p29cd and p29ce cyl2 misfire.
so ign coilbwas bad but cyl1 should be fine.
should I go ahead and change all ign coils?
how long to they last?
or take it to dealer if I can get codes to appear after cobb uninstall.
car is under cpo.
also there is oil in the holes beside the ign coil. not sure what the hole is.
how does the plug look?
      04-27-2014, 01:30 PM   #2
parabmw
Drives: 2018 m4
tried cobb stg 0 stock map. no misfires.
is that normal to have misfires only with maps?
what could cause it?
      04-27-2014, 01:38 PM   #3
tc535i
Drives: 2007 335i, 2001 330i, 1995 M3
Tune is more aggressive than stock, so while your components may just barely handle stock requirements, the agressive tune is too much. Start with new plugs.
      04-27-2014, 01:38 PM   #4
tc535i
Oil on the plugs means your valve cover gasket is shot
      04-27-2014, 10:19 PM   #5
parabmw
Drives: 2018 m4
no misfires with stg 1 sport. so far had misfires with stg 1+ fmic sport and agressive. both on 94oct.
      04-27-2014, 10:22 PM   #6
atheis
Drives: 2007 e90 TiAg 335i
had the same issue on cyl 6. just changed all plugs and 1 coilpack. good to go.
      04-28-2014, 08:53 AM   #7
BAL278
BAL278's Avatar
48
Drives: E92 335xi JB
yeah, I just swapped all my coil packs and that did the trick, was researching and I think they last around 40-45k miles for a tuned car (not 100% sure on that one as mine had a LOT more miles than that)
but you seem to have a bigger issue than just coils, looks like your valve cover gasket is shot
2008 335xi Jet Black//Coral Red
VTT Stage 1+// Procede V5//VRSF DPs//AMS FMIC//KW V1//M3 Sways & Sub Bushings// Alpina AT flash
Apex EC-7//Michelin PSS//Dinan CAI
      04-28-2014, 09:13 AM   #8
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
It's normal to throw a misfire with a tune vs without, just make sure to swap the bad coils and log a couple runs so you can make sure there's nothing out of the ordinary.
      05-04-2014, 03:37 PM   #9
parabmw
Drives: 2018 m4
changed plugs...no more misfires
      05-04-2014, 05:57 PM   #10
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
I just did the valve cover gasket, theres a diy by Rob ... $36 gasket, 4 - 6 hrs (i take my sweet time) - also look for any cracks in the valve cover itself when u take off ... becareful with fuel rails, triple check all screwed tight, drips from there could mean fire
oil in the cylinder cd mean head gasket leak I heard, open ur cooler bottle and see if it has any milky stuf, oil mixing w coolant
e90post
