E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Custom Carbon Fiber intake.
      04-24-2014, 03:44 PM   #1
peterparker
Drives: e90
2009 BMW 335i  [0.00]
Hey Guys,
So I have an itch for a new project, a Single Fat Filter CF Intake.
This will mimic the UR and Strett intake. Will be a short ram for ease of installation and maintenance. & CF due to less heat soak and awesomeness. Also I'm thinking of creating a simple CF heat shield with a air inlet from the factory scoops.
The Power Steering will be relocated to either the near the fire wall (Location of the 328i PS) or the near the bumper support (Look at the Injen Intake setup for reference.)
2.25" Inlets that merge into a 4" pipe. With options of a few K&N filters starting at 27.99.
http://www.knfilters.com/search/prod...od=RG-1001WT-L
http://www.knfilters.com/search/prod...x?prod=RF-1015
http://www.knfilters.com/search/prod...rod=RU-5171HBK
Going to make this clear the stock DV's (Because that's what I have) and trying to assume/guess clearance for VRSF's Charge pipe with a Tial bov.
Construction is going to consist of 4 thick layer CF (2x2 6k twill + Sleeve), west systems epoxy resin, vacuumed.
Since I'm going to create a mold, I might as well make more and sell them. Since there's like no CF intakes available for our cars under $1,000. So let me know if you're interested!
Any input and suggestions would be greatly appreciated.
Here's a quick sketch:
Update - Finished wrapping the Mold with casting tape.
4/30
I still have to make a few more adjustments to this mold because the inlet pipes are way out of spec. Because I kinda got happy with the casting tape.
Not to mention the actual CF will add about 6mm(.25in) in the total Diameter.
Update - Tweaking
5/2
Got the mold cut in half, Tweaked the mockup, test fitted, cut off the ends of the mold and re-casted the ends.
Next step: Lay the inside of the half's with fiberglass for reinforcement then join the 2 half's with a layer of fiber glass on the outside. Then sand and smooth away everything.
Finally I should be ready to create a fiberglass prototype.
Notes: Filter placement is really right. But I designed it so there's some room for play/movement. There's also a 5" tall filter I may try instead of this 7".
      04-24-2014, 03:47 PM   #2
CHECKERED
ex deus machina
CHECKERED's Avatar
Drives: G30, F15, Audi S4
Will need to see prototype first.
and I would strongly prefer a CAI or some type of ram air (from factory scoops) system
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK
Gone: E92 335i N54 468rwtq
      04-24-2014, 03:51 PM   #3
Myrder
Myrder's Avatar
Drives: 2010 E92 335i MSport 6MT LMB
Look at SLP blackwing
http://www.summitracing.com/parts/sle-21035b/overview/
I wanted to do something fun intake wise, but for the life of me could not find the dimensions of this filter!
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56|
-I will look on your treasures, gypsy. Is this understood?-
      04-24-2014, 04:13 PM   #4
peterparker
Drives: e90
Of course! Imma create one for my self first! Tweak tweak tweak till perfection! Then I can start slaving away!
Interesting! That's a cheap filter. doing some quick photoshopping with a ruler. Here's 2 possible measurements.
      04-24-2014, 04:17 PM   #5
N54POWR
Drives: 2011 335is
2011 335is  [8.66]
I'm always interested in cool diys. Keep us updated!
      04-24-2014, 04:44 PM   #6
Myrder
Myrder's Avatar
I'm almost ashamed I didn't think of that. Nice job. I was going to order one for tests but never got around to it. I did call SLP and they were to lazy to get one and put a ruler to it....
edit: looking at the screw clamp I think the 3" inlet is more probable.
      04-25-2014, 07:45 AM   #7
BAL278
BAL278's Avatar
48
Drives: E92 335xi JB
Keep us posted! I'd love to see this come to fruition
2008 335xi Jet Black//Coral Red
VTT Stage 1+// Procede V5//VRSF DPs//AMS FMIC//KW V1//M3 Sways & Sub Bushings// Alpina AT flash
Apex EC-7//Michelin PSS//Dinan CAI
      04-25-2014, 08:26 AM   #8
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Looks good!
My only suggestion is that you reinforce the filter inlet areas, every C/F intake I've seen generally fails at the main point of pressure from the clamps.
      04-25-2014, 09:22 AM   #9
_ink
Jedi samurai ninja turtle
_ink's Avatar
Australia
619
Drives: X3 M40i 2018
2018 X3 M40i  [0.00]
Originally Posted by Tiago@VRSF
Looks good!
Agreed!!
Would prefer it in hard AFE like plastic, and then wrapped in CF.
      04-25-2014, 10:22 AM   #10
peterparker
Drives: e90
Thanks! And let me know about that intake, I may have to downsize to 3.5 or 3 due to space constraints.
Will do!
Originally Posted by Tiago@VRSF View Post
Looks good!
Ahh ic! Thanks for the heads up, I'll def take that into consideration.
I was also thinking of cutting this intake in half, right after the merge. And slipping a v clamp flanges right over on both half's. Using epoxy to keep it in place.
Just for easier access to the charge pipe, easier installation and filter replacement. Since the preferred filter that I want to use is HUGE.
Whats your thoughts on that?
Will do!!
Originally Posted by _ink View Post
Agreed!!
I have no access to hard plastics! Nor a welder and/or anything fancy.. I'm just building this from my basement and garage. =\
Maybe down the road, I'll find a company that can reproduce this in plastic. Then yes!
The front intake air ducts will be rerouted into the heat shield; into the intake area. Does that Count as a ram air intake? Or does it have to be completely sealed off, like in a sealed box?
      04-25-2014, 06:43 PM   #11
nikitino25
nikitino25's Avatar
Drives: '07 E92 335i
Why don't you make something more along the lines of the Dinan or Mr5 type intake.....this design gives you two ports for incoming cool air, the same stock path and also the lower filter in the bumper area. I'm in process of making a Mr5 intake myself but using a 2.5" tube for the lower intake because of the structural bar in the way that I think only the e92 coupe has. It's slightly ghetto and I'd love to have some kind of plastic or carbon fiber tube like the Dinan but not willing to spend $1300 on an intake....
      04-26-2014, 01:14 PM   #12
Island Road
Drives: 335i
2008 335i  [10.00]
I would be in but I would want a direct CIA going straight to the FOG Light Delete mode used as a CIA Intake with K&N Apollo intake.
I have all the parts plus two different intakes one Applo and some other one that is larger but also enclosed just a matter of making the pipping now.
08 AW 6MT | MHD | Wavetrac LSD 3.46 | AE Quad | VRSF DP'S | VRSF 7" IC | DD Hood / Diffuser| Mtech Front / Rear| BMW Performance Splitters / Spoiler | Wheels 18lb 18x9 SQ | Hexon RR550 | TFT Inlets
      04-26-2014, 09:26 PM   #13
Zebra99
Zebra99's Avatar
Drives: 2011 335is E93
If you could make a Dinan replica in CF that would be awesome...CAI or nothing!
      04-27-2014, 12:11 PM   #14
uberbeast21
uberbeast21's Avatar
Drives: 2009 e92 335i
if you could make something like the stett intake but in carbon fiber that would be awesome, a little tricky, but awesome
e92 335i l Cobb l VMR V710 l BMW PE l KW V1 l Cusco strut brace l M3 Control Arms l BMS DP's l
      04-27-2014, 02:20 PM   #15
AYEDEE
AYEDEE's Avatar
Australia-Aboriginal
56
Drives: 3 Series BMW
Wow big task ahead of ya!
      04-29-2014, 01:02 PM   #16
peterparker
Drives: e90
The mock up piping is almost complete, Just waiting for the filter to come in for final fitment. Hopefully I can get the Fiberglass prototype done this weekend and then the testing starts! I'll post pics once that happens.
Changes-
There's no way the K&N RU-5171HBK dry filter would fit. And all other filters are oiled.
So I went with a smaller filter made from AFE. Looks exactly the same as the Takada filters.
http://www.autoanything.com/air-filt...cement-filters
21-40011
6" Base, 4.75 Top, 7" Height.
Also the intake pipe will be reduced from the original 4" to 3.25"/3/50" because there's no way I can fit a 4" intake in the space given.
You have no idea! Just making the mockup is a PITA!
Basically this is almost a strett replica... Sorry Strett!
Thats a lot of work! Perhaps in the future...
But I may make a CAI variant soon after. And I do want to make this intake modular with v band clamps. Just so I can swap out different filters / intake styles easier.
Looks good man! Keep me updated.
I may look into a MR5 style intake in the future one. And I agree $1300 on an intake is nuts!
      05-02-2014, 09:22 AM   #17
peterparker
Drives: e90
Updated!
Fitment is good once I removed the AC Bracket/Brake Booster bracket. I'll have to create a new bracket for that and the Power Steering. Also Clears the Stock DV.
But the real question is, Will I clear VRSF's CP with a Tial? Looks a little tight.
      05-26-2014, 12:10 PM   #18
uberbeast21
Updated!
Any update?
      05-26-2014, 04:16 PM   #19
LQQKOUT
Drives: 335XI
Good work! Keep us posted on the progress.
      05-26-2014, 06:02 PM   #20
Island Road
Drives: 335i
2008 335i  [10.00]
lol ugg nobody else seems any resemblance to the human anatomy here??
On a completely different note not related to the male genitalia 666 fabrication already did something like this, and is useless you make it a CIA going all the way down to the fog light no different than any other intake.
      05-27-2014, 08:30 AM   #21
peterparker
Drives: e90
Any update?
Not anything major, Just some more tweaking and modding. I also decided to downgrade to a smaller filter. 3.5in and an inch shorter for clearance. I still have to sand and bondo down the entire mold this weekend. Not really looking forward to this because working with fiberglass sucks! Even with a full protective suit.
Then finally CF process can start.
Thanks and I will do!
Ahh ic, Thanks for letting me know. I'll consider making a CAI version in the future.
But I will really consider that Power Steering Mounting option.
      05-27-2014, 09:52 AM   #22
FCobra94
Guest
n/a
Drives:
Word, Ultimate Racing makes one like that:
http://www.ultimate-racing.com/xcart...7&bestseller=Y
Looks great, but too rich for my blood.
e90post
