E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > poor timing numbers and pulled timing events, 19psi boost spike
      04-24-2014, 02:22 AM   #1
getInline
getInline's Avatar
Drives: 2008 335 Coupe, c32 AMG
I was wondering if anyone has any ideas on why my timing numbers are so low and why I get so many timing corrections and such a high boost spike during a run. I also seem to be getting fairly consistent throttle closure that looks like it's tied to overboost. Any help would be much appreciated!
http://www.datazap.me/u/getinline/ot...zoom=1127-1258
I'm running DCI, FMIC, OTS Vishnu v1.5 stage 1 map, Chevron 94
Spark plugs: stock bosch with 10,000 km
Fuel pump: 10000km on new pump
Injectors 3 new injectors have 10000km and the other bank has 30000km
Coils: all stock except for #3, just replaced it due to misfires
walnut shell blasting done 7000km ago
I have had this problem for years, always running poor timing numbers but just never get the time to delve into it enough to solve it. One theory I have is a faulty knock sensor, but that's just a guess since my timing numbers never improve much, even after getting new injectors and plugs.
      04-24-2014, 12:42 PM   #2
getInline
getInline's Avatar
Here is another log with less throttle closure but still plenty of timing retard events and poor timing numbers.
http://datazap.me/u/getinline/ots-vi...9&zoom=440-544
Anyone have any suggestions? I think I'm going to try logging all the knock channels to see if the timing retard events coincide with knock events....
      04-25-2014, 10:11 AM   #3
j1gilles
j1gilles's Avatar
Drives: 2009 335xi
Its 99% octane related in my opinion... I didn't look at your A/F ratio though.
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
      04-25-2014, 10:28 AM   #4
getInline
getInline's Avatar
Yes, Shiv wanted me to try VP109, I just had trouble getting my hands on anything less than a barrel. I think I'll try again!
      04-25-2014, 11:10 PM   #5
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
Load wedge's map you'll haul like a freight train
      04-26-2014, 09:29 PM   #6
getInline
getInline's Avatar
Is wedge's map for the OFT?
The more I look at other people's logs the worse mine looks.... I've never seen a log as bad as mine!
      04-27-2014, 12:33 AM   #7
stanlalee
Drives: 07' E92 335i manual
Not at wedge's map but at suggesting it's a map issue. That map with intercooler upgrade like he has should be peaking at 12 degrees of advance at redline all day long on regular 93 octane not 3. NO tune or map is going to fix the issue (save one with horrible timing advance). I would throw race gas at it to see what happens. Could rule in or out octane
      04-27-2014, 12:38 AM   #8
getInline
getInline's Avatar
Yes I understand, and that's what I'm trying to figure out, what is fundamentally wrong with my car to cause those poor timing numbers with a Conservative off the shelf map?
      04-27-2014, 11:58 AM   #9
getInline
getInline's Avatar
Anyone have any ideas on what can be causing timing numbers this bad? I'm running Chevron 94, which may not be great, but could it be this bad???
I know what can cause misfires but I can't figure out what can cause timing numbers like this other than low octane, high A/F ratio, or defective knock sensors?
      04-28-2014, 11:22 AM   #10
getInline
getInline's Avatar
British Columbia Chevron 94
Well I have an update. I did some searching and found a great thread on the Nissan GT-R forum about Vancouver, BC Chevron 94 (with no ethanol) gasoline.
http://www.gtrlife.com/forums/topic/...need-feedback/
Apparently it sends a number of stock GT-R's into safe mode and produces poor timing numbers even compared with Chevron 91 (with 10% ethanol), and this is based on a number of dyno and logging sessions. So it looks like Shiv may be right after all and explains why my car responds so well to methanol. I took my WW meth kit out last year and have a nice trunk mount tank waiting for installation. I wanted to wait to try and resolve my poor timing numbers before reinstalling my meth kit but it looks like it might be time to do that now.
      04-29-2014, 01:24 PM   #11
007_e350
007_e350's Avatar
Man its great Methanol gives added hp but huge fire risk - there are posts here ppl have burnt their cars due to meth just catching fire in the intake as IATs rose tremendously on the track ... better safe than sorry
      04-29-2014, 01:51 PM   #12
007_e350
007_e350's Avatar
Yeh for the OFT
      04-29-2014, 01:55 PM   #13
getInline
getInline's Avatar
True, but I don't track my car so I doubt my IATs could ever get that high. I'm also not going to run 100% meth, but something between 50-75% meth, to reduce the fire risk. That plus a trunk tank and a flow sensor failsafe is safe enough for me.
      05-02-2014, 04:18 PM   #14
getInline
getInline's Avatar
Well, in case anyone is interested I resolved my timing problem thanks to great information on the Nissan GTR forum about the poor quality of Chevron 94 in Vancouver (Chevron 94 thread).
I added about 2 liters of Bioflame ethanol (Bio Flame Ethanol) to 1/2 tank of Chevron 94 and voila, a big timing improvement....there is still one timing retard event and one throttle closure but overall it is a noticeable improvement!
OFT Vishnu 1.5 stage 0 map - 1/2 tank Chevron 94 with 2l BioFlame ethanol added
Looks like I'll need to go back to Meth spraying from my new trunk mount tank to maintain respectable timing numbers in Vancouver.
e90post
