E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Where can i buy a N54 Engine?
      04-23-2014, 09:19 PM   #1
Hollywoodsocal
Drives: e92
Shop diagnosed my car after some tests with either a cracked cylinder head or cracked block. im looking at 5800 if its cylinder head or 7900 if it is the block ( with labor) . Maybe its cheaper just to swap a new engine in? anyone know how much they may run for ? thanks ...
      04-23-2014, 09:36 PM   #2
Snypa
Drives: Like a mahdman !
Seems like same ballpark based on a quick look on eBay.
SUPER SLOW E90
      04-23-2014, 11:31 PM   #3
Ingeniator
Ingeniator's Avatar
Drives: 07 335XI(90) 09 135I(82)
Have another shop give you another opinion. A leak down test would tell you one way or the other and those would be the least likely cases for issues with compression loss two bottom end or cooling system. If it is windowed it would also be obvious. I wish you luck. Hopefully it's not this serious.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system
      04-24-2014, 08:08 AM   #4
Aubie4Pres
Drives: 2015 M4 SO/CS/CCB
http://www.car-part.com/ to find junkyards that have them around you. Give them a call to see what all is included...
e90post
