Engine Overheat Warning, but Temps are fine?
04-22-2014, 04:05 PM | #1 |
Rep 102
About 3mi into my morning commute, I got an "Engine Hot" yellow warning on the Idrive, then shortly after, it went red and said "Engine Overheat". Gas pedal was cut and I had to drift to the side of the road. The Oil temp was only at 180* on the gauge, totally normal range. I restarted and went a mile to a store, topped off reservoir with 3oz of distilled water to the max line. Same result 1/2 mi later so parked and got a ride into work. The radiator fan runs at 100%.
I changed the serpentine belt this weekend, so I'm worried I might have done something. If the water pump failed, I would think temps would be way high. If the tsat was stuck closed, I'd think the temps would not be moving up exactly at the normal rate. Think this is a bad temperature sensor of some sort? I will be connecting a BavTech tool later today to read codes. Also, this is a 2008 335xi with 85,000mi so the water pump is getting up there in age. Last edited by tahoerdr; 04-22-2014 at 04:26 PM.. |
04-22-2014, 04:17 PM | #2 | |
Rep 2,875
Both can be had for $475 shipped from Tischer Online, where I bought mine. Labor is about 5 hours (for both) for a noob mechanic with some help. Definitely less if you're a competent mechanic that has worked on N54s before, I'd say around 2-3 hours max.
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
04-22-2014, 04:23 PM | #3 | |
Rep 1,818
04-22-2014, 10:44 PM | #4 |
Some dude
92
Rep 1,780
Yes that's oil temp not water. Kinda dumb that there's no coolant gauge or dipstick.
Water pump is dead. Harder to replace on the X drive than a RWD, subgenre are different.
RRT
E92 335i/6MT with stuff and things |
04-23-2014, 02:05 PM | #6 |
Rep 102
OK thanks for the replies. I ordered the $475 kit from getbmwparts. The local dealer wanted $780 for the pump and tstat.
I'll be scouring the forums for any info on XI water pump DIY info. If none, I'll try to create one. Let me know if anyone finds some helpful install info, it would be much appreciated. |
04-23-2014, 03:38 PM | #8 |
Rep 2,875
OP,
While you're replacing the tstat and water pump, might as well flush the coolant, since you're going to have to drain it anyway. This will also be a good time to see if there's any 'fudge' coming out of the coolant tubes when draining. If there's anything brown/black that means your oil filter housing or VCG is leaking. After the install, don't forget to prime the pump by turning on the ignition (push 'start' button twice WITHOUT holding the brake), and then push the gas peddle all the way down for about 12 seconds or so. You should then hear the pump activating and running through the paces. If you don't hear the pump turn on and running. Then shut off the car completely and wait a few minutes, and repeat the process above until you hear the pump getting activated. You'll know when it's activated. The reason why I say this is because when I tried to prime the water pump after my initial install, nothing happened. It wasn't until I tried it the second time that the pump finally turned on and went through its paces.
04-23-2014, 03:39 PM | #9 |
Rep 1,818
cooling is a sealed system, why would oil be getting into it from a valve cover gasket or oil filter housing leak?
04-23-2014, 03:43 PM | #10 |
Rep 2,875
If you have opened a oil filter housing, then you'd know what I'm talking about....
If I'm not mistaken, coolant and oil run parallel within their own conduits, in the oil filter housing, separated by the infamous 'oil filter housing gasket'. When that gasket is deteriorated or leaking, coolant WILL get mixed with the oil. That's how and where the magic happens....
04-23-2014, 03:46 PM | #11 |
Rep 1,818
good to know, I wasn't aware they were separated by just a gasket there
will keep that in mind if I ever see signs of chocolate milkshake |
