what pilot bearing to use with spec steel single mass flywheel?
04-22-2014, 01:08 PM | #1 |
Rep 1,071
im replacing my clutch soon, everything is in the mail already, but something threw me off, when i was ordering some bolts and misc stuff from brevarian's website, when i entered the part number for the pilot bearing it says "To be used with dual mass flywheel"
will this pilot bearing also work with the single mass flywheel? or does the spec fw come with a pilot bearing already installed? thank you guys
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
04-23-2014, 08:14 AM | #2 |
Rep 1,071
anyone?
04-23-2014, 11:08 AM | #3 |
Rep 578
The pilot bearing that comes with the spec clutch is the same one as the OEM. It's also in the transmission and not in the engine like some cars. Not sure what special tool it takes to remove it as my car had low mileage and didn't replace it. So no issues here on running the OEM with the spec clutch/flywheel.
2008 135i - MHD/JB4, MS DP's, AMS IC, UI CAI, CDV delete, M3 control arms/Links, RE Toe Link, ECS Trailing Arm, M3 rear SF & Trans bushings, SS brake lines, Michelin PSS.
04-24-2014, 08:47 AM | #4 |
Rep 1,071
Thanks!
04-24-2014, 02:08 PM | #6 |
Rep 1,071
i have 100k in the car now!
