European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      04-10-2014, 09:59 AM   #1
djflex
Switzerland
22
Drives: M4 F82 ordered
Wheel Size
Does anyone already have an idea on which size of wheel is going to fit on the M4 without rubbing. I'm a bit curious because I found out that the Performance wheels are only 8" and 8.5" or so.
My car is supposed to be delivered by end of June and I would like to order a KW Clubsport and some 20" wheels so my dealer can mount everything straight away for delivery. But - right now I have 10inch wide wheels on my M3 E92 and I wonder if 10.5 will fit on the M4 without any bodywork needed - if yes which ET?
      04-12-2014, 11:14 AM   #2
AutoArmourSD
Drives: e90 m3
No one knows yet. No one has been able to get there hands on one to measure. I contacted HRE to order wheels and they have no specs to go off of.
      04-14-2014, 06:51 PM   #3
RSXDC5
RSXDC5's Avatar
707
Drives: M3
You will have at least a half inch on the inside and outside of the wheel...in terms of wiggle room. That being said, a 19x10 up front and a 19x11 in the rear will definitely work.
As for offsets, the front is +29 and the rear is +40, so anything around that (or a little lower) will work and not give you much of a problem. If you want to get more aggressive with fitment and need camber, you'll have to wait until camber plates come out.
Hope that helps!
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs
      04-15-2014, 07:50 AM   #4
djflex
Switzerland
22
Hope that helps!
thank you for your help. interessting that x11 will fit. i have x10.5 on my current M3 E92 and they fit exactly.
      05-28-2014, 01:01 AM   #5
XPNY
M4 Redliner
XPNY's Avatar
Drives: 2015 M4 Silverstone/SO
I tried ordering some vorsteiner wheels for mine and they're saying the same. No exact measurements yet. They did say 20s will fit but only with 25 profile rubber.
      06-02-2014, 03:00 AM   #6
djflex
Switzerland
22
Originally Posted by Carlos@MORR View Post
We have several sets in production. We are using 9.0"-9.5" fronts and 10"-11" rears.
Carlos, do you guys have a swiss retailer?
f80post
