E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Great Lakes > Shifting an auto 335 in the quarter mile?
      11-21-2007, 08:37 AM   #1
timtech
timtech's Avatar
25
Drives: M3
I have read that you should short shift the auto in a quarter mile run around 6,200. You guys that have ran in the 12's, do you short shift?
      11-21-2007, 11:40 PM   #2
ToothDoc
Drives: 997.2 TTS, CLA 45 AMG
Hey, good ET at Great Lakes - are you going again this weekend to see if you can get into the 12s?
      11-22-2007, 10:42 AM   #3
timtech
timtech's Avatar
25
Drives: M3
If the weather holds out, I may try. I'm too close to the 12's not to try. If I do go, I plan to try different shift points, check tire pressure and less gas :-)
Things I would try from what I read:
shift at redline in 1 and 2nd
then 6,200 there after...
and
shift every time at 6,200.
I may also try backing down on the brake torque. I was building rpm's on the line around 2,500-2,800 (to build boost), but I should really try around 1,800. It seemed the higher I went, it was a bit more bogged.
      11-24-2007, 10:27 PM   #4
ToothDoc
Too bad you didn't make it today. The DA at greatlakes was like -1100 feet!!!! Awesome ETs today. I got a 13.228 in a completely stock IS350 with spare tire and all. My best launch was a 1.918 but only topped out at 104.55 for that run so I got a 13.234 for that one.
      11-25-2007, 12:40 AM   #5
kevkaz
kevkaz's Avatar
Drives: Alpinweiss 2009 E92 M3
nice, sounds like you got a hot one... best i've seen published for the is350 is 13.7 and many higher than that.
2009 E92 M3 - 7/3/09 ED, 8/17/09 redelivery
1997 E36 M3 - Track Rat
2014 Jeep Grand Cherokee Overland
      11-25-2007, 01:09 AM   #6
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
any reply on the original topic?
      11-25-2007, 02:23 AM   #7
Vince@ V K Motorwerks
Vince@ V K Motorwerks's Avatar
148
Drives: 01 Black 911 Turbo, 09 X5
No, i dont short shift at all, All you have to do in an auto is leave it in DS mode. Hold down the break and raise the RPM to 2000 and then let the DS do the job. Oh make sure you hit the DTC button once. Changing the tires will greatly help aswell.
      11-25-2007, 09:07 AM   #8
ToothDoc
Couldn't Timtech raise the RPM a little more than you due to his AWD vehicle? He was already pulling 1.8's for 60 feet which is pretty good.
      11-25-2007, 09:10 AM   #9
ToothDoc
I don't think I've got a hot one - just good conditions. The week before another IS350 at great lakes did 13.3 but his DA was -800 vs my -1100. I think this is only average after a couple years of breaking in.
      11-25-2007, 02:19 PM   #10
timtech
timtech's Avatar
25
Drives: M3
That is VERY good for an IS350. I was there the last weekend and seen the other guy doing 13.3/13.4. He even put his radials into the water.
I just got back from going this morning and pulled a 12.930 at 108.74. I'm still getting 1.842 for a 60 foot. I have posted my slip to dragtimes in both the 335i and 335xi section - it can take up to 24 hours to show up. I found that 2,500 is best for the XI to launch at. More than that, the brakes start to let go. I ran four 12.93's in a row and headed out since it's very consistant for a car that can carry the family and drive in the winter.
I would say I'm very impressed with the Turbo Tuner. My Procede (1.47) felt stronger but a 12.9 is a 12.9 on a pretty stock car with all season tires.
      11-26-2007, 12:06 AM   #11
ToothDoc
Why did you get rid of the procede for a turbo tuner? BTW, congrats on breaking into the 12s! I want to mod to get into the 12s but there really aren't any good mods for my car. I am considering Volks which would reduce unsprung rotational weight by 40 pounds or so which should have a pretty big impact but I'm not ready to dish out 3k for rims just yet for my daily driver.
      12-20-2007, 06:35 AM   #12
Long Drive
Long Drive's Avatar
Drives: 2007 Monaco Blue 335i Coupe
Somewhere on this board is info on the new Dinan stuff for a 335i. In there are dyno runs showing max HP at 5600 RPM with the torque holding up pretty well at that point. I'd think if you're going to manually shift the auto, that'd be the point at which to do it. My '02 Camaro SS manual trans did it's best times with the shift at 5500 - 5800 rather than running it into the 6's. Might apply to the 335 as well.
      12-23-2007, 12:36 PM   #13
f30er
f30er's Avatar
Drives: F85
I've run all my best times in DS mode and pressing the dtc button just once....With it turned completely off, my times were all slower because of the wheel spin...
e90post
