Some wheel information /w photos. Forgestar SDC's and SemiDeeps |
04-02-2014, 08:22 PM | #1 |
Rep 775
I am in the process of developing a wheel with ADV1 for this car but needed to physically see what I was dealing with (actually mounted) on stock suspension. I took a set of wheel I had kicking around and just did a test fit. Here is a quick glance at some aggressive offsets.
19x10 ET27 19x8.5 ET35 So, I am thinking 19x10 ET36-37 should be perfect!
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 |
04-03-2014, 01:55 PM | #3 |
Rep 598
Just realised why.
You can't take a 10" wide wheel that's 5cm too wide, then put an 8.5" wheel on at nearly the right offset then assume the width of one and the offset of another will work. What you are proposing is 1.5" wider, therefore 3cm wider (at least) so 1.5cm extra either edge and only 3mm less offset so the wheel will still stick out. You'd need 10" x et50 approx I'd say |
04-03-2014, 01:56 PM | #4 | |
Rep 775
