Delrin Motor Mounts?
03-31-2014, 09:14 AM | #1 |
Rep 35
I might suck at searching the forums, but this is to let you know that i have tried
It's time to replace my mounts, and i would like to replace them with some delrin mounts. I was unable to find anything aftermarket for the N52, other than diff mounts. I did find some mention of a 335is upgraded mount... which works for the N52? Can anyone confirm this? And, does anyone know of ANY aftermarket motor mounts other than the M3 applications? Thank you! |
03-31-2014, 10:56 AM | #2 | |
Rep 247
Bilstein+Eibach, UUC F&R sways, Powerflex bushings, PE+Supersprint 2nd cat delete, Euro Intake+Silicone Intake hose, SS Brake Lines
03-31-2014, 01:08 PM | #3 |
Rep 259
Was this the thread you found? Looks like this guy used n54 mounts on his n52.
http://www.e90post.com/forums/showthread.php?p=14627536 If that is the case these should work for you. http://www.protuningfreaks.com/featu...mount-kit.html
2007 335xi 6AT | Cobb Stage1+ | BMS DCI | VRSF 7" IC | FA 500 400#F/600#R | ARC8 17x9 et30 | RE-11a 255/40/17
Parting out car. For sale thread here: http://www.e90post.com/forums/showthread.php?t=1167583 |
03-31-2014, 04:38 PM | #4 |
Master of my own domain!!
153
Rep 1,049
Anyone ever replace the driver's side motor mount. Found the passenger to be quite easy; however, finding space to remove and install that driver's side has posed a problem. Suggestions?
03-31-2014, 06:38 PM | #5 | |
Rep 35
