03-28-2014, 10:09 PM | #2 |
Rep 435
It is to be desired but functional. My car didn't have hard on kardon just the regular setup so no tweeters on a pillar....but has sub's under the seats. I had to max the bass and treble and crank volume to get decent sound. It has grown on me now and I put up with to end of my lease but next car will have the decent sound come hell or high water!
03-28-2014, 11:08 PM | #3 | |
Rep 1,079
2020 X3MC, 2018 Porsche Macan, 2019 X3 3.0i, 2016 981 Cayman S
03-29-2014, 02:11 PM | #4 |
Rep 109
I think the stock radio (and the doors that swing open way too easily) are my only gripes with my 228i. The stock radio on the 2011 328i sounded much better. In contrast, the one in the 228i sounds a bit hollow.
03-30-2014, 08:03 PM | #6 |
Rep 349
Does anyone know the number of speakers in the stock stereo? The count I'm noticing is this:
-2 in dash -2 (1 on each door) -2 (1 under each seat) -2 in rear window For a total of 8, so the harman/kardon adds 2 (1 tweeter in each window)? |
03-30-2014, 08:56 PM | #8 |
Rep 349
03-30-2014, 10:00 PM | #9 |
Rep 6,937
Drives: 2018 M2 AW DCT
They have always counted the two tweeters as separate speakers even though they are in the same enclosures as the mid-drivers.
03-31-2014, 01:23 AM | #10 |
Rep 2,337
I guess the base has 10 speakers? r/l front mids and tweeters, rear deck same and two underseat woofers... plan on skipping the hk system and buying an aftermarket system. without eq the system needs good speakers that can play flat.
03-31-2014, 08:04 AM | #12 | |
Rep 349
Speaker on the dash under windshield Speaker in each door Speaker under each seat Speaker in rear deck IF that was 2 for the dash, 2 for each door, 1 for each seat, that already makes 8, what would the rear deck be.... just one speaker with mid/tweeter? Cause if it's a r/l mid/tweeter, that makes twelve speakers in the stock stereo. I'm just trying to figure out exactly what the stock has and where, cause there's no documentation on it. |
04-06-2014, 11:04 PM | #13 |
Rep 6,937
The door speakers are three way speakers, a tweeter, a midrange, and a full range.
Has anyone replaced the stock speakers yet? I understand that focal's are about the only choice as a direct swap. |
04-07-2014, 11:31 AM | #14 |
Rep 349
So then that makes it 2 for the dash, 3 for each door (6), 1 under each seat (2), and 2 for the rear deck?
That is 12. UGH. No idea what's going on here. |
04-08-2014, 07:27 PM | #15 | |
Rep 6,937
No tweeters in the rear deck also. The rears are 4 inch speakers also. All the speakers are paper cones. |
04-08-2014, 07:31 PM | #16 |
Rep 6,937
So, the real count for stock is 8. The HK adds tweeters in the doors and each side in the back for a total of 12.
04-08-2014, 08:25 PM | #17 |
Rep 131
I'm sure you're correct, but I will say that if you play around with the online configurator and use the interior view when toggling the HK option on and off, it looks like it adds the tweeters in the side-view mirror "triangles", as well as something next to the door handles (to the left of them in the below images).
Attached images (non-HK on left, HK on right), but it's probably easier to spot when toggling on the configurator, as your eye is drawn to the differences. |
04-08-2014, 09:46 PM | #18 |
Rep 2,337
From the looks of the interior, that point next to the door handles is the only place the front speaker would go. So it looks like the hk option just uses a different mesh cover, lighter grey. Do the same with the beige interior. Much easier to see.
04-08-2014, 09:48 PM | #19 |
Rep 2,337
05-02-2014, 07:11 PM | #21 |
Rep 145
05-02-2014, 07:12 PM | #22 |
Rep 6,937
HK is about a 5 and stock is about a 3. You can do much better with after market speakers and amps.
