03-28-2014, 02:37 AM | #1 |
Rep 557
Advanced BT
As I purchased my car as used, via Bracknell how can I ascertain if I have ABT. Build date May/June 2013 with Business Media ie fiscal full size glass screen but only 6.5" internal unlike the Pro of 9".
Thanks
E46 325is MV Augusta Previously-E30 318is E36 323i
03-28-2014, 02:45 AM | #2 |
Rep 260
Did the garage not provide the original spec? If you call a BMW they should be able to tell you the original build spec of the car with you VIN.
Alex |
03-28-2014, 03:39 AM | #4 |
Rep 32,881
Do you mean Enhanced BT?
If you can select 'Audio' in telephone BT options then you have EBT. Also look under the boot floor for a combox, which means if you don't have EBT already you will be able to enable it by coding. |
03-28-2014, 03:44 AM | #5 |
Rep 1,858
like this one http://www.bmwarchive.org/vin/bmw-vin-decoder.html
you are looking for code S6NSA - Convenience telephony with extended smartphone connectivity |
03-28-2014, 08:35 AM | #7 | |
Rep 557
Spear wheel are is empty so assume I only have the norm. Presume unable to code? Will check the Audio. Also picking up new HTC One M8 later, hope all works! Side note I despise BB re previous thread!!!! All thanks for your useful input.
M140_BCS237.50 |
03-28-2014, 10:33 AM | #8 | ||
Rep 32,881
Not just spare wheel area, pull the whole boot floor out of the car then at the back (closest the seats) on right there's the fuse box, is there anything next to it on left? |
04-03-2014, 01:52 AM | #9 | |
Rep 557
Just looked in the boot and to the left of the fuse box is a Harman Becker Com Box, looks like an amp? Please could you advise upon my options do I need it coded can it be coded. Many thanks
04-03-2014, 02:53 AM | #10 | |
Rep 32,881
Follow my guide if you're up to it: http://www.f30post.com/forums/showthread.php?t=961515 Or if you don't think you can manage it then maybe ask someone on hear that's near you and can. |
04-03-2014, 03:09 AM | #11 | |
Rep 557
Is there anyone in the Hants/Dorset/Berks area that can do coding.
04-03-2014, 07:27 AM | #12 | ||
Rep 32,881
04-03-2014, 08:19 AM | #13 |
Rep 557
Many thanks
04-03-2014, 08:51 AM | #14 |
Rep 1,799
I have just done this coding to enable EBT by changing 6NH to 6NS and it seems to work OK. I now have "Office" in the iDrive menu and can listen to audio via bluetooth and have the 2nd phone option too.
Thanks teaston for your guide which was very helpful. I hope the car starts when I go out tonight and I haven't bricked it ! Is there any other coding that can be done without a token ? Where can I get the token from if not ? One thing though with the album artwork - before I did the coding the artwork didn't change from track to track whilst playing (it still doesn't either through USB or bluetooth). Anyone know why and how to fix the problem ? I have Pro Nav. If I disconnect the lead , restart Spotify,and reattach the lead then it changes to the current artwork but gets stuck again - quite annoying...
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
04-03-2014, 09:02 AM | #15 | |
Rep 32,881
Google tokenmaster blogspot, he makes the tokens for the patchless e-sys which i assume is what you have (from shawnsheridan) |
04-03-2014, 09:36 AM | #16 |
Rep 949
this has peaked my interest. I've got bus nav and no EBT and assumed I didn't have a comm box as my car was June 2013 build but just looked and that harmon becker silver thing is in there!
I don't have a fancy phone with apps etc but I do have an ipad so might be worthwhile. If I didn't have an ipad or a phone with apps, is it worth it? presume I cant get album artwork from my USB thumb drive with business nav and ebt. |
04-03-2014, 11:31 AM | #17 | |
Rep 32,881
Also yes artwork from usb stick & have yours and your partners phone connected for calls when your both in the car. So basically all you'd be missing not having an iphone is ability connect via usb to browse albums/artists etc through idrive. |
04-03-2014, 12:15 PM | #18 | |
Rep 949
I don't have voice activation (the button on the steering wheel with the face) , could that be activated? |
04-03-2014, 12:19 PM | #19 |
Rep 32,881
Yes my idiots guide says how to get basic voice activation, just for voice dialling.
03-30-2020, 07:45 PM | #20 | |
RC
Rep 1
