E90 Rear Squeal
03-26-2014, 06:24 AM | #1 |
Rep 333
E90 Rear Squeal
I have the infamous squeal coming from the rear passenger side at low speeds.
I have tried: cleaning out the brake dust applying anti squeal on pads sand down shoes and inner rotors But the noise comes back after a day. Upon another (closer) inspection, there were some marks on the inner side of the rotor where the shoes may be rubbing. This was sanded / rubbed down but made no difference. My mechanic tells me the discs and shoes fitted by the previous owner were not genuine and should be changed... Not sure if this will make a difference / resolve the issue, but dont fancy forking out 250.00 for discs and shoes unless theres no other option. Any suggestions? |
03-26-2014, 06:58 AM | #2 | |
Rep 307
03-26-2014, 07:07 AM | #3 | |
Rep 333
250gbp is just for the parts..!!! ;( There were some marks on the inside of the rotors (seem to be from the shoes). These were sanded down and applied anti squeal paste on the paste. but has not made a difference. The pads were replaced recently with genuine BMW pads. |
03-26-2014, 07:11 AM | #4 |
Rep 307
Oh dang I was thinking you was in the U.S. Sorry about that. That is some crazy pricing. If you have grooves I would still see if the rotors can be turned if you have that available there. If your pads are pretty new I would just sand them again after the rotors are turned smooth. That's about all I can think of to try and save some money. Y'all got some expensive parts there.
03-26-2014, 07:24 AM | #5 | |
Rep 333
The marks were not heavy... Just need to find someone nearby who can turn the rotors smooth. Or find non genuine discs and shoes... Any recommendations? Last edited by creativ101; 03-26-2014 at 07:30 AM.. |
03-26-2014, 07:32 AM | #6 |
Rep 307
Just a thought but it could also be the emergency brake shoes rubbing. Did you take the rotor off and check that. I would also clean and lightly Lube all the moving hardware. May have some dust in there causing it to squeal.
03-26-2014, 08:13 AM | #7 |
Rep 333
sanded the shoes and cleaned them up also... No luck there either.
