03-25-2014, 05:08 PM | #1 |
Rep 198
Seat height adjustment
Now is it me or does the seat not adjust to a very high on the sport seats? I have manual seat adjustments.
Any ideas on how to get the seat any higher? |
03-25-2014, 05:14 PM | #2 |
Rep 32,881
I would say the complete opposite, when i got my car i thought how low the roof is, my head was nearly touching it and i'm only 5'10"!
Then i remembered about the height adjustment and put it down a lot! |
03-25-2014, 05:17 PM | #3 |
Rep 260
Mines is near enough down at the bottom as well (I am 5' 9") I wanted to see how high it would go by getting out of the seat and then see how high it got without any of my weight on the seat.
Alex |
03-25-2014, 06:37 PM | #6 |
Rep 198
I prefer a slightly higher driving position and is the only draw back at the moment. Don't understand why the seat is designed not to go high basically!
Might have a play with the tilt lever and see if it improves. |
03-25-2014, 06:37 PM | #7 |
Rep 589
Seriously? Your head must be hitting the roof! I'm 5ft 10 and have to lower the height and also so I can fully see the dials!
F36 435D M Sport + Glacier Silver
Gone F30 320D 8AT M Sport Mineral grey Gone E92 320D M Sport Sparkling Graphite Gone E46 320D M Sport Silver Grey |
03-25-2014, 09:51 PM | #8 |
Rep 386
This could be an issue with the manual seats as I'm 5' 10" and with the seat right at the top of the travel, it's still not that high. Also, if you adjust the tilt it makes my legs sit at a ridiculous angle where they would probably be more comfortable resting them on the dashboard than trying to use the pedals...
03-25-2014, 10:18 PM | #9 |
YOLO
440
Rep 2,854
i'm 5'8 and my head hits the roof at highest setting
03-25-2014, 11:09 PM | #12 |
Rep 386
03-26-2014, 02:37 AM | #14 | |
Rep 1,224
i.e. If the seat is pushed forward and raised up it's easier to reach the roof with your head rather than seat reclined and pushed backward, the gap between your head and roof becomes greater. |
03-26-2014, 03:06 AM | #15 |
Rep 2,511
An interesting mix of driving positions... Coming from standard seats in an E90 the sport seats are so far superior!
I'm 6'0" and have the rear of the seat as low as it will go, the front of the seat as high as it will go... There is probably about 5" above my head but I'm comfortable. I can still see plenty of bonnet... I'm 'lanky' so the differential between front and back base height bends my knees. This allows me a comfortable position where I can correctly reach the steering wheel, which is pulled right back. Wrists on the top of the wheel whist fully pushing the brake pedal. It's taken me 3 weeks and 800 miles to refine to the position I'm in now.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
03-26-2014, 03:17 AM | #16 |
YOLO
440
Rep 2,854
03-26-2014, 03:29 AM | #17 |
Rep 949
There are a few threads on this. This OP got it sorted once he found the tilt lever on the front http://www.f30post.com/forums/showth...highlight=Tilt
03-26-2014, 03:40 AM | #18 |
Rep 198
Currently I am pulling he height adjustment lever and floating my ass in the air! i.e making sure my body weight is off the seat. But it doesn't seems to really get anywhere. Is it easier to adjust the height of the seat when not sitting on it. So if I adjust the height of the seat before getting in the car?
03-26-2014, 03:48 AM | #19 | |
Rep 198
03-26-2014, 03:54 AM | #20 | |
Rep 15,858
HighlandPete Edit: You've posted while I was typing my reply.... I see you are trying without full weight on the seat. Certainly try it with moderate tilt. |
03-26-2014, 04:28 AM | #21 | |
Rep 198
As you say, let me pump the seat height lever before I sit in the car to see how high it will reach. |
03-26-2014, 07:05 AM | #22 | |
YOLO
440
Rep 2,854
It's designed for that |
