REV vs. 1 % - Which matters most in staggered upgrade?
03-17-2014, 09:33 AM | #1 |
Rep 54
We can all agree that staying within a 1% rolling diameter is key when upgrading your wheels to staggered. There is also a lot of discussion about Revs per Mile.
Some members believe that if you are in 1%, you are fine, period. But, I've seen others say that you need to be within 3-4 Revs per Mile. Clearly there is a Green zone...within 1% and 3-4 RPMs. What do you think is more important? I just got into a setup which gave me a .7% on the wheel calculator, but has a 5 RPM difference. What results can members like me see? |
03-17-2014, 12:48 PM | #2 |
FSAE Dude
62
Rep 759
Or just don't get staggered setup. Then you definitely won't have any problems. Anyways I would go with the % number. Like if you make a bunch of left turns even with a staggered setup, your left rear wheel will spin as many or maybe fewer times that front right.. so I don't think it means much
03-24-2014, 03:52 PM | #4 |
Rep 54
Check RPM difference through either Tire Rack or the manufacturer's website. Typically they have tire specs and data available. It’s something interesting to consider.
03-25-2014, 05:53 PM | #5 |
Boooost!
70
Rep 793
Drives: 335i
I am having a vibration feeling when I let off the brake pedal I have a auto trans.
When I let off the brake pedal I start to coast forward and then after about 1-2 seconds it slightly slows down or a vibration feeling almost like a manual would stall out due to low rpms. 2nd gear is slightly worse. Is this because I have 335/35/19 front (818 revs) and 265/30/19 rear (821 revs)? I also used redline 75w90 in the front and rear diffs. Do they require friction modifiers?
JB4 Stage 2 | Injen CAI | BMW PE | AR Catless DP | Alpina TCU Flash | Eibach Pro Kit | Custom TCKline Koni's | 19" M359 Wheels | DWS Tires |
03-25-2014, 06:03 PM | #6 |
Rep 1,834
Drives: 08 E90 335xi TiAg
I have 235/40/18 and 266/35/18. I was told by many this is best if staggered. Recent front and rear diff oil change, t case flush/change and tranny fluid/pan/sleeve and filter.
Wondering if long term staggered is just not a good idea. |
03-25-2014, 07:08 PM | #7 |
Rep 311
Since staggered 18" was offered as a option in XI's, why would it matter if BMW was willing to raise the top speed from 135 to 155mph? The faster you go, the greater the rpm difference.
So as long as you kept with the % difference as the OEM staggered setup is, the risk is low. .....Unless the BMW engineers missed something, then your doomed! Last edited by critical05; 03-25-2014 at 07:15 PM.. |
