Eibach springs, not enough rear adjustment?
03-12-2014, 10:10 PM | #1 |
Rep 154
So I installed a Eibach prokit last year and had the car aligned. After the summer on my tires they were completely toast on the inside from the camber being out of adjustment. The alignment is within stock specs (I believe like -1.5*) and with the stock run flats I do not get this weird wear. The summers are wider (265's) compared to the stock tires however, so Im wondering if I need a camber kit? I was under the impression I wouldn't with just that slight lowering spring kit. Has anyone else had similar problems?
03-13-2014, 05:11 AM | #2 | |
Boooost!
70
Rep 793
Drives: 335i
You have to get your toe correct. Toe will tear tires up. I have eibach pro kit as well. Take it somewhere the knows and specializes in BMWs. If you are in PA and not too far from jersey, you should take it up to Auto Couture Motoring. They are the best.
JB4 Stage 2 | Injen CAI | BMW PE | AR Catless DP | Alpina TCU Flash | Eibach Pro Kit | Custom TCKline Koni's | 19" M359 Wheels | DWS Tires |
03-13-2014, 06:17 AM | #3 |
Rep 154
I looked at the actual chart from the alignment. The only thing off was the camber. If the toe was off wouldn't the stock tires do the same thing as far as wear? I don't get why only my summers got destroyed, I know the wear ratings are different but still.... I should get more than 8-9k miles on them
03-13-2014, 06:26 AM | #4 | |
Boooost!
70
Rep 793
Drives: 335i
03-13-2014, 07:43 AM | #6 | |
Boooost!
70
Rep 793
Drives: 335i
03-13-2014, 08:11 AM | #7 |
Rep 154
Well both sides wore exactly the same, to the point where the steel belts started showing, the outside of the tire is still decent, I didnt check until I took them off because I never would have thought they wore like that. I just dont know exactly what to do to correct it.
