E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > 255 race rubber / PROcede V2.02 track report
      11-12-2007, 12:43 PM   #1
leftcoastman
Drives: 335i
Recently, I spent two days wringing the snot out of my E92. Prior to this, I had been running stock wheels and the runflats. Not bad at all for runflats and I was generally posting quite good times.
First, some backgound:
Prior to this trip, I had put in an H&R rear sway to neutral out the handling. If anything, the rear sway made it a bit too tail happy and worse, made the wheelspin issue far more prevalent. The inside rear just spews smoke on any turns below 70mph. The day before, I installed PROcede V2.02 Beta.
Tires
Having corded the shoulders on two sets of fronts and one set of rear (inner edge, surprisingly), I decided to get some proper race rubber. Given the inability to apply power on corner exit, I decided to try to get as much entry/apex speed as possible. With the 225's, any attempts at that would result that in horrendous groaning that we all know as understeer.
So the goal was to stuff as much tire in front as possible. With the 255 Victoracer V700s on Kosei K1 17x8.5, I had a mere 4mm left between the inner sidewall and the strut tube. Luckily, deflection didn't cause any rubbing and that 4mm is plenty.
Wanting to be able to rotate the tires for longevity, I went for a non-staggered setup all around. You can imagine my fear going from a tail happy 225/255 staggered setup to a 255/255 non-staggered setup! Surprisingly, on track, the non-staggered setup didn't cause the car to excessively rotate. The wheelspin issue wasn't abated, however.
The race rubber, as you guys know, allowed me to operate effectively at exquisite slip angles. Even in 80-85 mph large radius hairpins, I was able to accelerate despite overloading the fronts. On street rubber, it would have been an exercise in futility to do anything other than ease off the gas.
Also, despite having a lot more tire drag (255 race rubber was equivalent to 275 or 285 street rubber in tread width), I was hitting slightly higher terminal speeds on the straights, probably due to faster exit speeds at the prior corner.
PROcede Version 2.02
Of course, the PROcede Version 2.02 didn't hurt on terminal speeds. For the first time, I had virtually no limp issues on track. As you track junkies know, just because something works on the street or drag strip does not mean it can stand up to track abuse.
Exhibit #1: oil cooler, lol. Even with cooler, on prior days, I could easily hit 285-290 within two laps. Luckily I didn't go much over it, so I never achieved heat induced limp mode. The autos were finished playing within a few laps, despite having oil coolers. Something about coolant temp issues. With the 70 degree temps, I wasn't hitting over 275.
I say "virtually" no limp issues with PROcede because I did limp once. I had been running 96'ish octane the first day, then that night went and filled to 3/4 with pump gas. I intended to go back and get some more racegas to raise octane, but alas the performance shop was closed! First lap around the track and "DING!". I have noticed that when you go high octane, transitioning back to low octane will cause limp modes, even in cruise conditions. The rest of the time was limp-less after the ECU adjusted, so chalk up one limp due to octane reduction.
The straights, which I usually see as the boring part between corners, was pretty fun. I was flying by the 997 S and was hanging with older Vipers. The looks of their faces were classic. The power is so smooth and instantaneous. I ran a few laps on stock form and god, the PROcede makes things smoother, in my mind. Smoother and umm, 33% more power without the tailoff at high rpm that plagued the stock setup. I screwed around with taking my dyno chart and applying the gear ratios to determine the optimal shift points. That eeked out a few more mph on the straights.
Final Results
I'm damn happy with this setup. The inside rear still lights up on all turns below 80mph, but even despite this, here is a list of cars that gave me the beloved point-by in my advanced group. I also posted faster "best" lap times.
- C5 Corvette on street rubber.
- 997 on race rubber driven by an instructor! He was not a happy camper and didn't let me by for a few laps. My video needs to be edited to remove my choice words, lol.
- Dodge Viper on race rubber that would lay waste to me on the straights. We're talking 20-30mph higher terminal speeds! He lay waste to a stock Z06 on the straights. It was blown, obviously. But while he was in the experienced group, he couldn't hang in the corners. I have the video and it's hilarious. Like a rubber band. He'd pull on the straights and I'd be braking mid-corner to avoid slamming his bumper. Very cool guy. He gave me the point-by and later told me he wanted to watch my line because I was clearly outcornering him with an inferior vehicle. (thanks?). But seriously, his vehicle was a beast. I watched an instructor drive it and it lay waste to everything out there.
- My greatest accomplishment was holding off an Ariel Atom for 4-5 laps. Earlier in the day, I'd give the point-by anytime I saw it coming up on me. But as I got better at handling race rubber, I got some damn fast times. People were very very surprised with the little Bimmer that could. It was like a rubber band with the Atom also. He'd get within 3-4 car-lengths in the corners but I would slowly pull away on the straights. He never got close enough to necessitate a point-by, as confirmed later. To his credit, he had a passenger. If he was alone, I would have just thrown the finger out soon as I saw him in the rearview.
Damn, the season is over already? I'm seriously considering an LSD for next season. With that and some more cajones in some of the wall-graced corners, I think I can eke a few more seconds out. I can't wait to try.
      11-12-2007, 12:49 PM   #2
sdiver68
Expert Road Racer
59
Drives: 07 335i e90, 09 335i e93
Excellent post, thanks for cross-posting in the other forum so I could see this one.
      11-12-2007, 01:00 PM   #3
Hegemony
Fast Like Tiger
Hegemony's Avatar
Drives: 07 M Coupe
I'm hoping I get mine by Dec 1st, so I can post a track review as well.
      11-12-2007, 01:04 PM   #4
PresaMat
PresaMat's Avatar
Drives: 67 GT500,69 Boss 429, 335i
Great write up! Out of curiosity what kind of oil are you running? Also do you have any coolant additives (water wetter etc)?
Happy to hear v2 2.02 worked well. What would you say the average mph on the course? Also what rpm etc. Trying to get a feel for how "hard on a car" this course was.
Definitely sounds like its time for an LSD. Thanks again for the great report!
-Mat
Tuned E92 335, Riss Racing downpipes! And hopefully over 400RWHP!!
      11-12-2007, 01:08 PM   #5
stressdoc
stressdoc's Avatar
Dominica
617
Drives: BMW i8; Toy 4runner TRD pro
LSD, maybe more suspension balance work?
      11-12-2007, 01:16 PM   #6
leftcoastman
Drives: 335i
Nah, I like the stock suspension. A little floaty now and then, but I don't want to kill the on-road comfort for less than a second on the road course.
I'm sure I can shave more than a few seconds by working on the loose nut on the wheel.
      11-12-2007, 01:33 PM   #7
Serjames
Serjames's Avatar
Drives: E93 335i M-sport
In the Uk, we're now convinced that anything over stock necessitates that LSD, with procede it's just silly, I'm gonna shred this tyre in under 4 months.
E92Fan is booked in for his quaife and (as soon as i can save up lol) I'm not far behind.
SJ
      11-12-2007, 01:41 PM   #8
OC ///M
Dr. Octagon
OC ///M's Avatar
Drives: Moonstone e92 M3
Very nice write-up. I also thank you for cross-posting this. What was the name of the event, track location?
OC ///M
2013 E92 M3 Individual
Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB
      11-12-2007, 01:53 PM   #9
mayno
Drives: 2007 335i / 2018 BMW 430i Conv
very nice report and great job! you definitely seem like a seasoned track driver. wish I had more time to do this stuff. have only been to Willow Springs twice, but that was w/ my previous car (03' M3).
      11-12-2007, 02:35 PM   #10
sambonator
Samtaro!
sambonator's Avatar
Drives: 2014 F32 N55 Alpinweiß
Excellent Report! Thank you!
BTW what size 255 tires did you get? 255/40/17's?
Also, any reason why you went with 17x8.5 wheels instead of 18x8.5?
I got 18x8.5 for tracking, but now wonder if I should have gone with 17s?
      11-12-2007, 04:15 PM   #11
leftcoastman
Drives: 335i
5w40 Valvoline synpower. No water wetter at all.
      11-12-2007, 04:18 PM   #12
leftcoastman
Drives: 335i
Precisely.
I went for the 17s because:
1) The rims are cheaper and lighter. At $165 a pop and 16.8 lbs, you can't beat it.
2) The tires are cheaper and more available.
3) The Koseis will fit over the brakes, unlike some 17s.
      11-12-2007, 04:19 PM   #13
S4to335
Drives: 2014 Audi A4 / 91 Track Miata
Originally Posted by leftcoastman View Post
Nah, something a little further west.
Spa? Imola? Nurburing?
Car is now gone .... :-(
      11-12-2007, 05:12 PM   #14
bmwzimmer
bmwzimmer's Avatar
35
Drives: 335
leftcoastman, I went on tirerack and they won't let me configure 17" wheels if the car has a sports package. They will if your car doesn't have sports packag. Will your 17' Koseis fit both?
      11-12-2007, 05:25 PM   #15
oddjob2021
ASR Turbos+LSD+Meth= :D
oddjob2021's Avatar
73
Drives: E92 335i
2007 E92 335i  [0.00]
wow beat a carrera? nice kill on the track ... great write up, i look forward to further results
2007 335i Coupe
Mods: Check the Garage
      11-12-2007, 05:29 PM   #16
leftcoastman
Drives: 335i
Yes. Sport pack here.
      11-12-2007, 05:33 PM   #17
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
942
Drives: 997.2 GT3
good write up!!! dont see how you could kill a 350bhp Atom in a straightline tho? he exits from the corners must have been wank. You must be a good driver!!
get the vids up, with full ''running commentary'' LOL
Carlos
997.2 GT3
      11-12-2007, 05:41 PM   #18
Evo8MRto335I
Evo8MRto335I's Avatar
Spain
40
Drives: can't list them all
Awesome write up. You can't go wrong with the Kosei K1s... How much do the front OEM 18" weight? I was thinking about also buying the front Kosei K1s set for my car (I already have the rear ones).
      11-12-2007, 05:43 PM   #19
leftcoastman
Drives: 335i
Carlos
Three reasons:
1) It isn't the latest and greatest Atom with 350bhp
2) An additional passenger screws his power/weight.
3) His aerodynamics are crap, so above 120mph, he's in the crapper and those front fenders are great lift inducers.
Nothing will wake you up like having your steering wheels lift off the ground at high speed!
      11-12-2007, 05:45 PM   #20
leftcoastman
Drives: 335i
I believe I saved about 15lbs a corner. The non-RFT are heavier than the runflats. Everyone bitches about the RFTs, but the stock ones aren't really heavy.
Keep in mind, as you probably know, the K1s will not win any beauty contests. They are appliances and they work well for what they are intended for: Light track wheels.
      11-12-2007, 06:39 PM   #21
baron
Drives: 2011 BMW 528i
Leftcoastman,
Great write up, thanks. What kind of track experience do you have? Where did the event take place?
2011 BMW 528i
2009 Nissan GTR
      11-12-2007, 07:06 PM   #22
T Bone
T Bone's Avatar
530
Drives: 2008 335xi Coupe
Nice write up!
Are you taking pyrometer readings after a couple of hot laps??
"Aerodynamics are for people who cannot build engines"......Enzo Ferrari
e90post
