Water Leaks!
02-21-2014, 11:00 AM | #1 |
Rep 257
Water Leaks!
Hi all. I have 2 water leaks getting water inside the cabin.
1st one. Happens only during heavy rains, when I stop quick or turn hard I get water dripping from the console where the lights and sunroof buttons are located... almost to the point of a steady stream at times. I should assume this is coming from the sunroof or could it be from the windshield? To my knowledge the windshield in this car has never been replaced. What should I do to check/address the sunroof seals? 2nd one. Rear driver foot well gets wet no matter what kind of rain. I do know when I bought the car I had the dealership replace the window motors on that specific door. Should I pop the door cover off and check for anything in particular? |
02-22-2014, 05:02 PM | #2 |
Rep 310
Your assumption regarding No. 1 sounds correct. Check the drain tubes on the forward section of the sunroof cassette.
Regarding No 2, sounds like a broken vapor seal on the driver's side rear door. This is very common on BMWs, and more common after a repair has been performed in the area. The tech failed to secure the vapor seal cover on the door. There are many threads on how to correct these 2 issues on the forum. Last edited by GearRex; 02-22-2014 at 07:04 PM.. |
