02-20-2014, 12:36 PM | #1 |
Rep 29
Forgive me, still need help with Adaptive M Suspension
Forgive me in advance, I know this has been discussed, just not sure I am understanding correctly. I have search and read and remain confused.
Anyway, I am ordering an M3. Not sure if I want, or need, the Adaptive M Suspension. As I understand it, the Drivelogic allows for 3 settings, Comfort, Sport and Sport Plus - but these will only apply to gear ratios and throttle response, not suspension settings? Thus, the ONLY way to change from comfort, sport and sport plus in the suspension settings would be to get the Adaptive M - otherwise, the car comes as is with one suspension setting? Am I correct? I am a low mileage driver, 4 miles each way to work. I am planning on keeping this car for at least 10 years. I will not be tracking the car, and my roads are in pretty good shape here in PHX. Never had a car with suspension settings and I was planning on not checking this box in the M3, but seems many deem this as a must have. Any advice is greatly appreciated! I know it has been discussed before, but I look here for expert advice explained in a way that a guy who loves fast cars but doesn't understand them...can, you know, understand this! Thanks again. LBH |
02-20-2014, 12:59 PM | #3 | ||
Rep 19,368
But forget the stuff you said about throttle response and gear ratios. It has nothing to do with the suspension. The only thing those two things have in common with the suspension is that all three can be adjusted - either using MDrive or M Driving Dynamics Control. http://f80.bimmerpost.com/forums/sho...d.php?t=946048 Quote:
02-20-2014, 01:21 PM | #4 |
10811
Rep 27,597
good rule of thumb on options: get as many options as you can afford bc it will greatly help down the road when you go to sell it, just my 2 cents.
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
02-20-2014, 02:50 PM | #5 |
Rep 2,104
I fairly recently made a thread about this. Got some really good info. To answer your question, you are correct: the only way to change the suspension to comfort/sport/etc is to have the Adaptive suspension. And as mentioned above, if you don't get it, the suspension is passive, not active. To clarify, in theory, you COULD have an active, but non-adjustable (comfort/sport/ect) suspension, but that is not what you get on the M3/M4. TBH, if I were in your shoes, I'd just get it. It's realtively cheap ($1000), and you will probably have a nicer ride overall. To me, I don't know a TON (just a little) about suspensions, but the best suspensions, whether active, passive, adjustable, coil-overs, re-bar, whatever, are ones that just get out of the way, so you don't even notice they're there. They're not too harsh/soft/etc, they are just RIGHT for your purposes.
02-20-2014, 04:11 PM | #6 |
Rep 817
Drives: E30 M3 Darth Vader Trackcar
and please get up early and drive more than 4miles each way to work. Do not drive the car unless you can drive far enough to get all fluids up to temp. This is the reason engines get gummed up, never driven right or hard.
T |
02-20-2014, 05:04 PM | #7 | |
Rep 1,248
On topic- I fell in love with the Adaptive sups 6 years ago and wouldn't want an M car without it now. Loved the E46, but man was it a rough ride. $1,000 gives the best of all worlds. Last edited by Carl L; 02-20-2014 at 05:10 PM.. |
02-20-2014, 05:09 PM | #8 |
Rep 29
Funny having this discussion. When I had my Cayman, I used to find alternative routes to the office so I could enjoy the car in the morning and evening - I am sure I will do this with the M3. I should make clear though that the 4 miles can take 20 minutes - so usually the car gets warm.
Looks like spending the $1k on the Adaptive M is a smart play. I think I will add that to the every-gowing list. Thought I could get out for under $65K with ED - and I was close, until the damn Exec Pack, see my other thread on this. This is the one part of the buying process that makes me want to walk away from BMW, $4300 for a bunch of crap....and then oh yeah, those two important things like rear view and sat radio.... |
02-20-2014, 06:13 PM | #10 |
Rep 26
M Adaptive suspension
I would definitely get the M adaptive suspension, comfort mode is much more comfortable on those bumpy sections. Sport mode tightens everything up nicely!
02-20-2014, 06:22 PM | #11 | |
Rep 20,741
Drives: 2021 911 turbo
There is no such thing as a "must have". Everything depends on personal use and preferences. You don't track and the road are smooth were you live, so you will not get as much benefit from the EDC. However, for me, EDC does accentuate the flexibility/adaptability the car provides and $900, it is a bargain. |
02-20-2014, 07:35 PM | #12 |
Rep 10,509
I have it in my current car and I'm not planning to order it.
I think the key advantage is the softest for commuting and the trade offs are potential feeling that the suspension isn't predictable when driving hard, potential for $$ fix in the future when the system has a failure, need to disable the system when going to an aftermarket suspension |
02-20-2014, 08:00 PM | #13 |
Rep 1,317
if i plan on getting coils, whats the point of this option? by not getting it, i think it saves the headache of not having to by-pass a fault light that comes on when .. the edc light or whatever.. if I'm not mistaking
02-20-2014, 08:06 PM | #14 |
Law Enforcer
25060
Rep 22,281
Drives: '22 Chalk Gray Porsche C2S
02-20-2014, 08:13 PM | #15 |
Rep 7,298
that is plenty time for the engine to be warmed up....unless its freezing outside....
02-20-2014, 08:20 PM | #17 |
Rep 1,282
I've had the adaptive on two cars now, and I don't plan to order it on the M3. It's a gimmick.
M850i Vert with RaceChip
E46 M3, Euro Headers, Rasp Pipe, Kassel Tune Alpina B8, zero performance mods |
02-20-2014, 08:23 PM | #18 |
Law Enforcer
25060
Rep 22,281
02-20-2014, 08:50 PM | #20 |
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
02-20-2014, 09:06 PM | #21 | |
Rep 6,691
Warm, as in "will blow warm air" or if the coolant temp gauge gets up to temp, is not hot enough. You need to get the oil temp up to operating temp (which can take 10-15 minutes even in warm temperatures) and stay there to burn the water out of the oil, etc. |
02-20-2014, 09:38 PM | #22 | ||
Rep 7,298
