Window error code!!
02-14-2014, 12:27 PM | #1 |
- Speed Matters -
11
Rep 228
Window error code!!
I have this annoying window error code comin up every 2 minutes since having a new battrey put in, all 4 windows work fine in manual and auto mode.. Any1 know what the prob is here?
Thanks |
02-14-2014, 02:14 PM | #2 |
Rep 9,097
Try this:
An initialization must be performed: • In the event of malfunctions, e.g. no one-touch control function, no opening or if available no comfort function is possible • After the power window drive has been replaced • After work is carried out on the power window mechanism • If necessary, after an open circuit, e.g. disconnection of the battery or disconnection of the power supply to the door • After the door window glass has been removed and installed or replaced • After adjustment work on the door window glass • After adjustment work on the convertible top • After replacement of seals Initialization is performed on the power window switch of the relevant door. Requirements for correct initialization: • Terminal "R" activated • Doors and windows closed • Sufficient battery voltage; connect charger if necessary Initialization comprises: • Erasure of initialization • Reinitialization Erasure of initialization: • Open door window glass fully • Actuate power window switch in "Open" position (second switch position) and hold down for between 15 and 20 seconds This clears initialization of the power window. Anti-trapping protection and one-touch control (toll) function are inactive. Check whether one-touch control (toll) function is inactive, otherwise repeat procedure. Reinitialization: • Close door window completely • After upper end position is reached, interrupt actuation of power window switch and then hold switch again for approx. 1 second in "Close" position (second switch position) • Open door window glass fully • After upper end position is reached, interrupt actuation of power window switch and then hold switch again for approx. 1 second in "Open" position (second switch position) • Close door window completely • After upper end position is reached, interrupt actuation of power window switch and then hold switch again for approx. 1 second in "Close" position (second switch position) This completes initialization. Note: Carry out function check (one-touch control function, anti-trapping protection and, if necessary, comfort function).
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
02-15-2014, 09:27 AM | #3 | |
- Speed Matters -
11
Rep 228
