European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      02-12-2014, 04:53 AM   #1
Dackelone
European Editor
Dackelone's Avatar
Germany
10511
Drives: N54 e82
F80 M3 / F82 M4 Wheel Offsets (ET) and Sizes
Ok guys... I have the info you ALL have been dying for...
Summer wheels
- 9x18 (ET29) +10x18 (ET40), Style 513M
- 9x19 (ET29) +10x19 (ET40), Style 437M
Winter wheels
- 8,5x18 (ET27) +9x18 (ET29), Style 640M
- 9x19 (ET27) +9x19 (ET29), Style 641M
18" 513M on Yas Marina Blue
18" 513M on Austin Yellow
18" 513M on Mineral White
18" 513M on Black Sapphire Metallic
19" 437M
19" 437M Black
Winter wheels: 640M and 641M
Appreciate 10
      02-12-2014, 06:23 AM   #2
CanAutM3
CanAutM3's Avatar
Drives: 2021 911 turbo
Many thanks for that info Dack
Much appreciated
davem3fan185.50
      02-12-2014, 06:29 AM   #3
mkoesel
Drives: No BMW for now
Thanks Dackelone!
      02-12-2014, 06:34 AM   #4
M4ever?
M4ever?'s Avatar
Germany
Drives: M4
Thanks a lot Dack - most interesting post for a while
      02-12-2014, 06:40 AM   #5
RealStig
RealStig's Avatar
51
Drives: M3
So i guess we can forget about using E9X M3 wheels without spacers.
      02-12-2014, 06:56 AM   #6
Dawko
Belgium
191
Drives: :
  [0.00]
I'm surprised these offsets are so high? Were E9x M offsets the same?
I was expecting something like 10" with an ET of 25-30mm.
      02-12-2014, 07:08 AM   #7
RealStig
RealStig's Avatar
51
Drives: M3
M3 offsets were all ET29/ET23 I think. As I was expecting there is a big difference.
      02-12-2014, 07:24 AM   #8
AlpineE92M3
Currently Driving
AlpineE92M3's Avatar
269
Drives: BPM tuned '13 AW ZCP E92 M3
2013 BMW E92 M3  [0.00]
2011 BMW M3  [0.00]
Will I be able to swap my ZCP wheels on the M4 and vice versa? I told my SA I want to keep my ZCP's for the M4 and they can have the M4 rims to put on my E92 when I trade. Are the lug patterns the same?
      02-12-2014, 07:30 AM   #9
RealStig
RealStig's Avatar
51
Drives: M3
I dont think you can based on what's posted above.
      02-12-2014, 07:40 AM   #10
AlpineE92M3
Currently Driving
269
2011 BMW M3  [0.00]
It doesn't say anything about the lug pattern. I run 15/12mm spacers on my ZCP's so it basically makes them same offsets as the M4's
      02-12-2014, 07:50 AM   #11
mkoesel
Spacers?
A positive offset is measured from the centerline of the wheel toward the outside of the wheel. So, the larger the number, the further *inward* the wheel sits.
Let's compare to the style 359M from the E9x competition package, since they are the same size wheel as the 437M on the F8x.
Front: 9x19 ET31
Rear: 10x19 ET25
So then, the front 359M sits just 2mm further inward than the 437M, and the rear wheel sits *15mm further outward* than the 437M. Spacers are definitely not going to help here. What we need is extra clearance from the fender lip. We'll see if that works out once someone bolts them up. I'd say there is a chance it will work, but it may need to be rolled. Of course, the other issue is that it will not have the same flushness as the front, which rolling the rear could alleviate. Or you could put a 15mm spacer in front, which is probably not a good idea.
davem3fan185.50
      02-12-2014, 07:52 AM   #12
Black Gold
Drives: M3
I don't think you understand wheel offsets.
The OEM ZCP wheels vs F8x wheels are
19x9 ET 31 vs 19x9 ET 29 - -2mm for F8x
19x10 ET 25 vs 19x10 ET 40 - +15mm for F8x
So basically, swapping ZCP on the new F8x would be 2mm less aggressive in the front, and 15mm more aggressive in the rear. So you could get a nice flush fitment by running ZCP and say a 12-15mm spacer in the front with no spacer in the rear.
All depends on fender clearance and how the OEM wheels fit on the F8x. We will find out how much room they have once the cars are in our position and we can take some measurements.
      02-12-2014, 08:38 AM   #13
RealStig
RealStig's Avatar
51
Drives: M3
I should have been clearer, I don't like using spacers, so oem to oem, you cannot swap them. With spacers, sure why not.
Sorry for confusion.
davem3fan185.50
      02-12-2014, 08:41 AM   #14
Black Gold
Drives: M3
yes, you can swap them. its just the rear will be more aggressive than stock and the front will be basically the same fitment as the f8x stock rims.
it can certainly be done.
if your point is that the offsets aren't identical between the two cars, yes that is correct. but they definitely will fit and probably will be popular with a front spacer. the good thing is that the offsets allow for a large spacer which typically fits much better and more flush on the hub. 15mm spacers are ideal in my experience. depends on fender clearance, but I bet it will fit.
      02-12-2014, 08:47 AM   #15
mkoesel
Read carefully, you appear to still be confused.
Spacers will not be necessary to get offsets that meet or exceed OEM specifications.
      02-12-2014, 08:49 AM   #16
-JLT-
-JLT-'s Avatar
3420
Drives: '22 X4M COMP, '23 iX xDrive50
I'm looking for an aggressive setup, but in your opinion:
Would 19x8.5 ET15 (front) and 19x9.5 ET22 (rear) wheels be flush?
      02-12-2014, 08:56 AM   #17
Black Gold
Drives: M3
this is the best tool for making these calculations....
http://www.1010tires.com/Tools/Wheel...ulator#Results
first of all, I wouldn't recommend a narrower wheel like that, its important to have wider wheels that support the sidewalls fully. BMW engineers in slightly stretched wheels/tires which IMO help decrease body roll and aid in steering sharpness. so I would highly recommend at least a 9/10 inch width, especially with a 255/275 tire.
that said, here are the results.
fronts will be 8mm more aggressive than stock (should definitely fit and be noticeably more aggressive, but not overly aggressive.
rears will be 12mm more aggressive than stock, and look about right.
again, I wouldn't recommend narrower wheels, but it can be done and it will fit.
its hard to say what the most aggressive fitment is, because we don't know how much more offset the car can take and still fit in the fenders. it also depends on if you will lower your car etc....
      02-12-2014, 09:52 AM   #18
jbockrd
jbockrd's Avatar
Drives: e92 Alpine White/Carbon M3
I am new to this, I have an 18 inch wheel setup for winter on my e92 M3. Will I be able to keep these wheels? Are spacers necessary or not? I'm not looking for deep answers, I'm a medical guy so keep it simple!! LOL
On the list for an M4!!
      02-12-2014, 10:01 AM   #19
Black Gold
Drives: M3
need widths and offsets to answer your question
use the calculator I provided in my prior post and plug in your wheels and the OEM bmw winter wheel data provided in the OP in this thread.
      02-12-2014, 10:06 AM   #20
JTO24
never could compete with Lloyd Braun
JTO24's Avatar
Drives: 2022 G80 M3 6MT
Yup, KP nailed it.. I use that link frequently as I'm doing my due diligence on a new wheel set up.. Great tool and easy to use.
      02-12-2014, 10:15 AM   #21
signes
signes's Avatar
Drives: 991 GT3 RS
+1, nice and concise.
GT3 RS | Desperately seeking the next great M car...
davem3fan185.50
      02-12-2014, 10:17 AM   #22
signes
signes's Avatar
Drives: 991 GT3 RS
Dackel, thank you for the information!
f80post
