E93 boot leak
02-11-2014, 09:44 AM | #1 |
Rep 109
E93 boot leak
Hi everyone, with the recent weather I discovered that there are water in the 2 side compartments in the boot of my 2010 e93 Anyone else experienced this? What can I do? Shall I take it to bmw? Thanks
02-12-2014, 12:50 PM | #3 |
Rep 1,023
i had this problem it almost friend my amp.
ended up pulling the rubber plug around the exhaust vacuum line running out the bottom of the right side compartment. dealer was trying to get me to pay thousands to replace roof seals. put the amp on spacers and pulled that plug and never looked back. it also never happened again. this happened after a bad rain storm |
02-12-2014, 09:04 PM | #4 |
Rep 1,184
i have this problem, i figured it was because i have an aftermarket bootlid (but i guess not)... atm i've got a towel over each side which soaks up all the water nicely... when i do the sounds im gonna put extra rubber around the seals to get it to be water tight...
that is dangerously close to the battery :\
PAST: 2007 E93 335i 6MT NOW: 2012 F10 M5 Facebook: Achu Ckr|Twitter: AchuCkr|Instagram: AchuCKR|Flickr: AchuCKR|G+: achu.ckr THE BUILD THREAD|COMPILATION OF PHOTOS |
02-17-2014, 07:23 AM | #5 | |
COBBY
Rep 14
Drives: 2008 E93 325i Convertible
If possible, get someone in the boot with a torch and run a hose over it, you may need to remove the lining inside on the left and right. |
02-26-2014, 05:20 PM | #6 |
Rep 1,184
http://www.e90post.com/forums/showthread.php?t=864436
sorry, i just found this and it will help you a lot
