blown turbo, seeking advice
02-01-2014, 11:36 AM | #1 |
Rep 34
As stated above, I'm assuming the turbo on my 320D has given up the ghost.
the car has covered 96,000 miles. been driving it around today, few runs to the local tip clearing my garage out, then earlier i went to the cash point, turned the car off. when i got back in the car, turned it on and pulled away, it was totally flat ! NO BOOST ! [/B] theres no oil leaking from anywhere, and theres no white smoke coming from the exhaust. the good news.... my girlfriends dad used to be a BMW mechanic for BMW and now has his own garage restoring classics and building hot rods. on inspection he seems to think it could be the turbo actuator as it is boosting slightly then losing pressure. There isn't any warning lights on the dash. the car is now parked in his garage on the ramp for him to have a closer look. I'll be doing the work but i'll have free rain over all his equipment which should make the job easier. now for the advice! if it is a turbo I need, is there anyway of uprating it ? for example, could i fit the turbo from a 325D ? does it take much modification to fit and run? or should i just play it safe and replace with a new 320D turbo ? Regards, Marc |
02-01-2014, 02:51 PM | #3 | |
Rep 2,554
Here's my common sense though I assume it would fit considering the turbo size differences aren't immense. |
02-02-2014, 12:28 PM | #4 |
Rep 321
02-02-2014, 12:31 PM | #5 |
Rep 321
Several things spring to mind, actuator being one of the things
MAF sensor Boost leak: If the turbo is trying to get boost and it's leaking from somewhere, you'll get a differential between asked for boost and actual boost. If this is the case, I'm surprised that the car isn't showing the engine management light A pipe may have blown off somewhere also. Just my twopenneth. |
02-03-2014, 08:13 AM | #8 |
Rep 1,093
Rarely or ever do you get a blown turbo without accompanying noise. I've blown a few and while I didn't get any smoke etc the turbo bearing makes one hell of a noise when its blown.
02-04-2014, 04:16 AM | #9 |
Rep 34
had a phone call with my girlfriends dad last night who was having a look at the car, he took a few pipes off to check them over, put the ar back together and now it's fine !
pulls like a train he said. so I'm happy that it isn't the turbo. what he did suggest though, was to replace the Vac pipes as the car has covered 96,000 they will be getting tired and probably start to perish. So I'll replace them and see how I get on. |
02-04-2014, 05:45 AM | #10 |
Rep 321
Having had a few Golf GTDs, I heard many anecdotes about local roadside repair companies (RAC, AA, etc) who carry zip ties with them JUST for the Golf Blown Hose issue :-)
02-04-2014, 06:43 AM | #11 |
Rep 501
Could you explain what "free rain over his equipment" means?
02-04-2014, 01:43 PM | #12 |
Rep 791
Drives: 2011 550xi
One would think he means reign.
2017 Nitro Blue Ford Focus RS 2008 Sparkling Grey Metallic 135i 6MT - JB4 G5 - MHD Race BEF - N54Tuning DP's - ER Chargepipe/w HKS SSQV - Coolingmist Progressive Meth - MMP Hot Side Inlets - AFE Exhaust - Seconday Cat Delete - AMS FMIC - BMS Catch Can - Rob Beck PCV - LUX 160 AE |
02-04-2014, 01:54 PM | #13 |
Rep 14,829
02-04-2014, 03:13 PM | #14 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Any chance a vacuum hose is loose? It's worth a quick look.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
02-04-2014, 03:39 PM | #15 | |
Fuck it dude, let's go bowling.
888
Rep 2,480
Hey OP, still working ok? What pipes did he pull?
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
