FAO PE owners - can you take a look
01-31-2014, 11:02 AM | #1 |
BM Noob
24
Rep 975
I know some 325i owners have PEs on their cars but so far they've all been 3.0l versions. Just trying to check it'll go on mine. Taken some poor, but best I could, underside pics to see if it looks the same and if the PE will fit?
02-03-2014, 05:22 PM | #2 |
Rep 1,093
Yes, i got a 2009 e90 lci 325i 2.5 litre, they still sold few of them in Asia before replacing it for the 330i over here, i also got the PE installed too, all good you can get it done.
02-04-2014, 04:53 AM | #3 |
Rep 3,194
Drives: E92 325i MSport Coupe
Yes, you're good to go. The part number for the 325i is:
B18.30.2.217.676 and you don't need a clamp because it comes supplied with one. Make sure you ask the supplying dealer to provide you a copy of the BMW fitting instructions, as you will need to cut the pipe and the instructions give you the key measurements for this.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
02-04-2014, 03:51 PM | #5 |
Rep 3,923
there is a small indent on the original pipe about 2-3 inches above where it comes out of the box. you cut here with a reciprocating saw remove the hangers and there is also a big black rubber buffer and away you go you may need some wd40 on the hanger rubbers to get them off not a difficult diy really. its best to use the oem bmw clamp as cheaper ones will do but the oem does a much better job. if you buy mine I will help you fit it!
02-05-2014, 05:46 AM | #6 | |
Rep 3,194
http://www.e90post.com/forums/showthread.php?t=740755
02-06-2014, 04:23 PM | #10 |
Rep 2,692
Hey insane
Im in the UK. I cant remember the size of the tips. I'll measure them and get back to you. The exhaust will be up for sale in the next week or so and how. |
02-06-2014, 04:29 PM | #11 | |
Rep 1,093
I sent you a PM. UPDATED.. Last edited by insane79; 02-06-2014 at 04:44 PM.. |
02-07-2014, 03:03 PM | #13 |
Rep 3,923
02-08-2014, 10:27 AM | #15 |
Rep 3,194
Yes you can - you just use the same clamp supplied with the PE.
