Burning Smells on WOT
01-30-2014, 11:37 AM | #1 |
Rep 149
Lately when I go WOT, immediately I get a burning smell, which then dissipates a few moments later... It doesn't seem to happen any other time, even 'spirited driving' doesn't seem to cause it... Any ideas?
2008 335i |
01-31-2014, 04:20 AM | #6 |
Rep 791
Does this happen only on sudden transitions to WOT? Might be worth checking the aux belt on the front of the engine - early 335i had issues with the left-hand engine mount allowing too much twist, letting the bottom pulley collide with the subframe and rubbing the belt under sudden load. Doesn't sound hugely likely, though...
2019 VW Golf GTI Performance | H&R rear ARB
Previously 2007 E92 335i SE auto | Quaife LSD | Birds B3 ARBs | Evolve Stage 1 |
02-01-2014, 03:59 AM | #8 |
Rep 149
I keep reading about plastic bags stuck to exhausts...! Surely if that was the case though it'd be constant.
Actually it does only happen on sudden transitions to WOT... I'll check out the aux belt but being a 2008 I'd hope that isn't the case! Could it actually just be unburnt fuel? Strange! |
02-01-2014, 05:18 AM | #9 |
Rep 791
I'd expect unburnt fuel to smell like, well, fuel, rather than burning!
02-03-2014, 02:11 PM | #14 | |
Rep 1,445
07-07-2014, 02:33 AM | #17 |
Rep 127
I get this as well mines manual and its not clutch exhaust lasts for a few seconds then goes .To me its a burning oil smell but uses no oil at oil and no smoke out the exhausts .
F10 M5
07-07-2014, 08:53 AM | #18 |
Rep 1,445
07-07-2014, 01:39 PM | #20 |
Rep 1,445
It can be tricky to spot but I have seen the 6 cyl engines seep at the back left corner where no.6 is and drip onto exhaust creating a dirty patch.Itll never lose a noticeable amount of oil and it never hits the ground/ under tray as it gets burned on the exhaust.
