OE audio aftermarket amp + subs or just change hu?
01-29-2014, 03:37 PM | #1 |
Rep 102
I have noticed in scouring the threads and post that there are few custom audio set ups. Is this because the E9x has so many limitations for this?
I would like blue tooth, nav and to be able to have good quality outputs to feed an amp and I can find very little to support this plan. I have a directed 1100d5 amp and 2 x 12s that I would like to fit to my new car. I also want to add a comp system up front. I am in no way an audio file, but have always sought to improve over OE. I would also like clarification on whether or not the OE head needs to remain installed if choosing an aftermarket HU? Any advice? |
01-29-2014, 10:43 PM | #2 |
Rep 2,216
Drives: E91 330d M Sport
The HU is linked into the CANBUS network so if you remove it, IIRC you have to code it out.
I've got the basic HU with iDrive, then a Cleansweep, amp, subs and comonent speakers. Night and day difference. If you keep the HU though, you'll either have to have the HU recoded to HiFi or use a DSP of some sort. HTH
Just how many Yorkshire sheep can you fit inside one exhaust?
01-30-2014, 04:01 PM | #3 | |
Rep 102
01-30-2014, 04:16 PM | #4 |
Rep 303
HI everything you need to know should be in this thread.http://www.e90post.com/forums/showthread.php?t=641323
blackchrome csl,s // eibach pro kit //bitstein B4s// shortened bumpstops//front and rear brembo performance brakes// jbl ms8//focal 100krs// rainbow dlx5 centre, rear//jenhert xe200//cas audio corner loaded sub// jl10v3 sub// jl xd500/3 xd400/4// technic harness// 808mguy adapters |
01-31-2014, 04:24 AM | #5 |
Rep 2,216
