E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > unstable temp. Is it a thermostat problem.
      01-19-2014, 07:35 AM   #1
Jules59
Jules59's Avatar
Drives: Still searching ...
Normally my cars (2009 330D LCI N57) temp is steady at 96C according to my Torque Pro app on my phone.
Today cruising up the motorway with cruise control ON at 2000rpm I noticed on the hills the temp rose to 101C and dropped to 93C on the descents. Giving it some welly it never went above 101C. This widely fluctuating temp is a new issue. The car appears to be running well, has done just over 40Kmiles and managed 43mpg on the 100mile trip.
On reflection Ive noticed a slight increase in temp variability over the last month but as most of my journeys are about 10 miles it didnt jump out at me. Today was a the first long motorway trip Ive done since Xmas.
My feeling this is a thermostat issue. What do others think?
Are there any DIYs on changing the thermostat/s on the N57 engine ? Or is it just like the M57 ?
Jules
      01-19-2014, 07:55 AM   #2
Dan-danGT
Dan-danGT's Avatar
Drives: E90 330d M-Sport
That don't seem to bad for a uphill climb. But 96c is not hot at all. 101c is not really hot, I had my 330d Upto 112c on the nurburgring last year and I never got a coolant temp warning.
Just monitor it but I don't see much problem with that also could have been regenerating
      01-19-2014, 08:07 AM   #3
makkan00
makkan00's Avatar
Drives: F83 and F36
On Petrol, its a different story. I have changed the coolant on my car and replaced it with BMW OEM coolant. Kept an eye on the temp in the hidden menu.
During the summer it was going upto 110C without fan kicking in.
Fan kicks in at about 118C on petrol car (320i). If you drive it in italian style, temp goes up and goes down with cruising. I had 120C max and after searching on internet, I found it was normal for a petrol car.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      01-19-2014, 09:17 AM   #4
Jules59
Jules59's Avatar
thanks. ok i wont worry. I guess its why BMW removed the temp gauge.
Odd how much the temp changes though - I've never noticed such variance on other cars - perhaps the difference between an analogue gauge and a digital readout.
Jules
      01-19-2014, 11:41 AM   #5
dj219957
dj219957's Avatar
Drives: 2009 e90, cic idrive pro
this is why temperature gauges are damped in cars! to stop people worrying about fluctuating temperatures. bmw chose to remove theirs all together. dont worry about it, its normal.
      01-19-2014, 01:46 PM   #6
Oxygen Thief
Oxygen Thief's Avatar
Drives: E70 X5 3.0sd M-Sport
I'd be more than happy with those temps! I've got the same engine and my temps only get in the region of 88-92C and i'm getting 39mpg average. Looks like its time to get both my thermostats changed if you're hitting those sorts of temps!
Phil
      01-19-2014, 04:13 PM   #7
335DEE
335DEE's Avatar
England
38
Drives: M3 DCT
more than likely DPF regen if getting upwards of 100 . if it drops to below 82 when up to temp , then change BOTH your stats .. they ALL go weak in time and bugger the DPF
      02-18-2014, 03:24 PM   #8
Jules59
Jules59's Avatar
Phil
Ive changed the thermostat and guess what, I'm getting a steady 89-91C. No more 93 -103 swings.
Jules
      02-18-2014, 04:51 PM   #9
Dan-danGT
Dan-danGT's Avatar
Main stat opening temp is 86c I believe so 88-92c I would think is normal that's all I see in my 330d. You coud have been in a regeneration which is why temp was higher than normal. Also I can manage 43 mpg on a run and my temp is not much different to some others posted
      02-19-2014, 05:06 AM   #10
tmarshall57
tmarshall57's Avatar
Drives: F10 530d M Sport, E87 118d M
88-92 is completely normal on a 330d
F10 530d M Sport, September 2012 Individual Amazonite Silver, Oyster Dakota Leather, Auto, Nav Pro, Bluetooth + USB Devices, Expanded BMW Online, Comfort Seats, Sunroof, Sun Protection Glass Individual Satin Walnut Honey Brown Trim Interior Inside/Outside Mirror with folding and autodip, M Rear Spoiler
e90post
