ABS Pump failure - ball park costs?
01-15-2014, 05:09 AM | #1 |
Rep 183
Hi Guys and Gals,
Sods law occured this morning.. Car has been faultess as per normal.. Today is MOT day and as I pull off up the road the ABS light comes on (with some other associated ones).. I get to the MOT Garage which happens to be my Local Indie.. They say the ABS pump has gone... Ball park quote £1000... Any thoughts? Being a positive man.. the car sailed through the rest of the MOT... Cheers Tarbs |
01-15-2014, 07:58 AM | #2 |
Rep 102
http://www.ecutesting.com/bmw_common...FUzHtAodFWsAHg
Seem to recall a few posts where people used this company. |
01-15-2014, 02:57 PM | #3 |
Rep 623
Drives: F10 530d M Sport, E87 118d M
On a 6 cylinder engine the full part (mechanical pump and electronic module) costs around £1,800. The mechanical unit (repair kit) is around £900.
Send the whole unit to ECU Testing and the cost will be approx £250 including testing, repair and return postage. Do not send to BBA Reman. On a 4 pot the repair kit mentioned above is about £200.
F10 530d M Sport, September 2012 Individual Amazonite Silver, Oyster Dakota Leather, Auto, Nav Pro, Bluetooth + USB Devices, Expanded BMW Online, Comfort Seats, Sunroof, Sun Protection Glass Individual Satin Walnut Honey Brown Trim Interior Inside/Outside Mirror with folding and autodip, M Rear Spoiler
01-18-2014, 04:22 PM | #4 |
Rep 5
ABS pump refurb
Yeah, go to www.ECUtesting.com and fill out the online form with the part number of the unit and they'll let you know if they can repair/refurb it. If they can, remove and send it to them and once they get it they'll turn it around in 3 days with text updates to let you know what's going on (£255). I got mine back last Thurs and mechanic fitted Fri morn and so far so good. Forget BMW. Get yourself a good indie and it'll be all sorted for a fraction of the price. Thoroughly reccomended.
01-24-2014, 02:44 PM | #5 |
Rep 183
Guys - thank you ever so much for this.
It has turned out to be an interesting saga. Because I am time bound this is going to be a bit squeaky.. I am certainly not paying the ridculous price that BMW want.. My Indie, who I really do see in a different light after my last two visits, doesnt want to get involved in the whole ECUTesting.com thing.. So i took the car back (MOT doesn't run out till the 28th Feb) and a mate is going to look after the car and get it to his Indie who said he will sort it all in for about £400. Will keep you posted. |
01-27-2014, 02:32 PM | #6 |
Rep 183
This morning the lights and errors all cleared.... I've done nothing
Car going for MOT tomorrow. |
01-27-2014, 03:24 PM | #7 |
Rep 623
Lights will return. With any luck after your MOT.
10-30-2014, 10:59 AM | #9 |
Rep 2,796
Another ABS issue yep they seem to be going down good and proper, refurb unit wise is the most cost effective way we've got 2 in progress now down side is the cars off the road for a week or so.
Steve |
10-30-2014, 02:59 PM | #11 |
Rep 2,796
all 4 cylinders are cheap by comparison, the repair kits around £142.80+VAT plus fining and brake fluid and fault clearing, therefore making it look damn cheap compared with a 6 cylinder model
07-07-2015, 05:01 PM | #12 |
Rep 81
Instead of starting a new thread i thought I'd revive this one... So, the abs light came up on the dashboard the other day, with two other lights, the hand break light (in yellow) and can't remember the other one, I used the code reader and the codes that came up where
005DF0 - pump motor faulty 005DF1 - pump motor connector damaged I've had a look around a few other forums, and it's seems to be a VERY common problem with the 07 year, I've seen people say it could vary from Faulty wheel sensor Faulty steering angle sensor Faulty wheel bearing Battery on the way out (low voltage) ABS pump I've had the car just under two months, it's under warranty with 'Warranty first' for another month, so my plan is to book it in with BMW and let them fiddle about. What is the most likely scenario? A nackered sensor? or the worst case, the pump? |
07-07-2015, 05:40 PM | #13 |
Rep 623
For those codes it is definitely the ABS unit. They are etched in my brain. Send the whole unit to ECU Testing after phoning them or filling out their online form.
07-07-2015, 06:58 PM | #14 |
Rep 258
funnily enough (well not actually that funny), mine has gone too, in at BMW today as i still have the extended warranty on my 335. They mentioned the cost would have been the unpleasant side of £1500
07-08-2015, 08:49 AM | #16 |
Rep 686
A colleague at work just had his done think he paid £240 inc vat for the Unit repair then a couple hours labour to remove and fit. prob under £400 all in
07-09-2015, 10:11 AM | #19 | |
Rep 129
07-09-2015, 01:07 PM | #20 |
Rep 81
Took the car into Bmw today, but as I pulled off, the lights disappeared..decided to take it in anyway because they'll no doubt return.. BMW rang to say the lights have not come back on since they've had it, but the codes are still there, and the pump will need replacing at some point, so it's over the the warranty company to see if they give the go ahead!
Seems to be a very common fault on 07 plates! |
