E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Dab retrofit
      01-12-2014, 11:21 AM   #1
Snappy russ
Drives: E91 msport
Dab retrofit
Hi people this is my first post on here. I've had my e91 330d m sport for just a year now. Small mods led interior light and a remap , but that's it so far. I'm curious if anyone has fitted an aftermarket dab radio kit. My audi had it fitted and I do miss it. Seen a few options available but has anyone got a recommendation.
Cheers for looking
      01-12-2014, 11:53 AM   #2
bungleaio
Drives: Pug 208
What sort of headhunt do you have at the moment? I drive?
Welcome to the forum.
      01-12-2014, 12:51 PM   #3
Snappy russ
Drives: E91 msport
Sorry my apologies. 2006 with prof nab and I drive
Thanks
      01-12-2014, 02:29 PM   #4
makkan00
makkan00's Avatar
Drives: F83 and F36
OEM
http://www.ebay.co.uk/itm/Bmw-Dab-Ra...item3389936705
+ antenna
After market
http://www.ebay.co.uk/itm/DABMotion-...item3a85a35c9f
http://www.ebay.co.uk/itm/DAS-Digita...item4ac0c80cd2
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      01-12-2014, 03:04 PM   #5
Snappy russ
Drives: E91 msport
Thank you for advice . Is the oem a good system compared to aftermarket. It looks cheap on eBay (probably won't finish that way) the last option looks a bit out of budget what's the difficulty in fitting the oem
      01-12-2014, 03:18 PM   #6
jammy78
Drives: F31 335D
Originally Posted by makkan00 View Post
Sam, can this be installed with CIC?
Cheers
      01-12-2014, 03:53 PM   #7
makkan00
makkan00's Avatar
Drives: F83 and F36
For OEM, you will need to buy OEM antenna which is around £250 from the stealer. You will need to fit it, connect to the car and code it. Quality will be better compared to any after market kit if you install OEM antenna.
2nd option is the cheapest and works reasonably well.
      01-12-2014, 03:54 PM   #8
makkan00
makkan00's Avatar
Drives: F83 and F36
Cheers
Jammy
CIC requires built in DAB tuners and does not accept the external units unlike CCC.
      01-12-2014, 04:09 PM   #9
GP87
Drives: Current:F82 M4 Previous:F83 M4
Jammy
http://www.mobridge-ipod.co.uk/iPhon...bridge-BMW-DAB
Cartronics claim to have a mobridge aftermarket solution that works with the CIC, would be interesting.
Nevertheless, BMW internet web radio has a wider selection available, which you can access through your CIC with combox.
      01-12-2014, 04:19 PM   #10
makkan00
makkan00's Avatar
Drives: F83 and F36
Jammy
I referred to OEM solution.
There are many aftermarket solutions which can work with CIC.
      01-12-2014, 04:36 PM   #11
jammy78
Drives: F31 335D
Oh yeah - I keep forgetting about BMW Internet web radio!
Cheers
      01-13-2014, 07:30 AM   #12
Hopeful
Drives: BMW X3 G01 30d 2018
Is that true? OP has an E91 and I thought that antenna was in rear window(s)
e90post
