E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Seat Creak
      11-03-2007, 04:59 AM   #1
BC4J
BC4J's Avatar
Drives: F30 328i
2007 E90 335d  [0.00]
Seat Creak
Anyone here experienced the driver's seat creaking? Mine's started to do this during braking and accelerating, and if you move back and forth in the seat when stationary. I've done a search and found people complaining of this, but not found a definite cause or cure. Time for a trip to the dealer methinks...
Behold! F30 328i M-Sport - Tanzanite Blue with Opal White Leather
      11-03-2007, 05:02 AM   #2
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
948
Drives: 997.2 GT3
yes i have found the passenger seat squeeks if someone is sat in it! does piss me off, new cars especially BMW's should not do this. I do have a solution though, would you like to hear it....???
Turn DAT DAMN STEREO UP TO DA MAX MO FO
997.2 GT3
      11-03-2007, 06:12 AM   #3
hmi1750
hmi1750's Avatar
25
Drives: M135i
get some silicon seal spray... from most autoshops. I sprayed along where the leather(ette) lower parts of the seat rub on the plastic trim, and it sorted out the drivers side... though I need to do the passenger side still.
      11-03-2007, 08:45 AM   #4
M3-FAST
Defected to the dark side.....
M3-FAST's Avatar
England
210
Drives: BMW M5 LCi
My drivers one is doing the same - every time you accelerate away it creaks with your bdy weight pressing against it. - also when you are cornering it creaks
It is going into the dealer on Wed to have the new clutch and flywheel fitted s will mention it and see if they can look at it whilst it's in. I won't hold my breath tho as I asked em to look at it last time they had it. The car got delivered back with the seat still creaking and not a word from the stealer since
BMW customer service is lacking in quite a few dealers from what I gather reading some of the recent post's on here!
Paul
      11-03-2007, 08:46 AM   #5
silverbmwz3
Drives: X5 g05
I just want to know what Carlos is doing in the passenger seat to make it creak.
Current: E90 335d (May 2007) | Black/Black | Prof Hifi | Prof Nav | 6FL | Fully Electric Seats | Xenons | Folding Mirrors | PDC
Previous: 325ci Conv. Black/Black with lots of ACS
Previous: z3 3.0 Silver with Black&Red Leather
      11-03-2007, 08:49 AM   #6
dxb335d
dxb335d's Avatar
England
948
Drives: 997.2 GT3
997.2 GT3
      11-03-2007, 01:51 PM   #7
creepy coupe
creepy coupe's Avatar
1867
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
My drivers seat does it.it's the right hand bolster, anoying because ever time I depress the clutch I notice it.
      11-03-2007, 05:23 PM   #8
M3-FAST
M3-FAST's Avatar
England
210
Drives: BMW M5 LCi
Is that the cause of the creak then - the leather and plastic surfaces rubbing against each other??
anyone got creaking fabric/cloth/alcantara seats? - this may confirm it!
      11-03-2007, 08:42 PM   #9
Noize
Under the radar
Noize's Avatar
Drives: FWD in reverse
Mine does this and I **hate** it. Its a really loud creak, definitely not the leather. Its the seat itself. Its especially bad under acceleration and braking.
      11-03-2007, 08:47 PM   #10
E92Fan
E92Fan's Avatar
Drives: .
When you accelerate, does the seat make a clicking sound as your body weight shifts backwards? It does on mine, then clicks when the bodyweight goes forward as I brake. It sounds like a seat-runner bolt is loose and there is movement in the seat frame, but I've gone round with a wrench and tightened everything as much as I can. I've even sprayed lube oil down there, everywhere, but it didn't help. My dealer doesn't even know what it is (although that's not suprising, given the current state of my car )
      11-03-2007, 08:52 PM   #11
E92Fan
E92Fan's Avatar
Drives: .
I used to have really bad creaks from the back of my car, but managed to diagnose it down to slightly brittle leather that hadn't been treated in a while. After a good dose of leather feed and conditioner, the creaks completely stopped. Well, that is until the rear seat frame started creaking, and the parcel shelf, and the rear seat mounts.... !! I conditioned the front seats too, and it did help a lot to reduce squeaking. Also, it seems to be protecting the driver's side seat bolster a lot more from the wear and tear it will get from me (being on the more portly side) getting in and out.
At the moment, I'm using a leather feed and conditioner from DFS Sofas, but might try the Zymol stuff as it's actually a little cheaper unbelievably!!
      11-03-2007, 09:18 PM   #12
Noize
Under the radar
Noize's Avatar
Yes. I just fixed mine with this. Check it out. I hope it works!
http://www.e90post.com/forums/showpo...7&postcount=40
      11-03-2007, 09:21 PM   #13
E92Fan
E92Fan's Avatar
Drives: .
Fantastic. Will try that when I get my car back eventually. Thanks a lot
      11-04-2007, 05:58 AM   #14
BC4J
BC4J's Avatar
Drives: F30 328i
Thanks. The guy who reported this fix originally came back a day later to say the creak had returned! Then he posted this:
http://www.e90post.com/forums/showpo...4&postcount=19
and this:
http://www.e90post.com/forums/showpo...6&postcount=22
I've booked my car in for next Monday so I'll take this info along so they fix it properly!
      11-04-2007, 07:45 AM   #15
Noize
Under the radar
Noize's Avatar
and this:
Yes, my strap was not caught. I will report back if the PB Blaster (lubrication like a really good WD40) does not keep the problem away. The creak was definitely coming from that pivot joint.
      11-06-2007, 03:32 PM   #16
dazzapb
Drives: 2019 X3M Comp
i had a noise coming from the passenger seat - underneath - so i just sprayed some carbaflo! what a cowboy.. but it did the trick!
pricey stuff but the nuts
http://www.carbaflo-direct.com/findoutmore.html
      11-07-2007, 02:43 AM   #17
Steve A
Steve A's Avatar
Drives: too much
Ive heard on the grapevine that the volume of the seatcreak is in direct proportion to the size of the arse which is sat upon it
C350 cdi sport estate facelift 457lbft
130i M SportMercedes C350 CDI Sport Estate AutoMini Cooper Auto.Mercedes E250 CGI,Lexus IS-F,R36, RS4 Saloon,ML 420 CDI SPORT,M6, 335d, C55, C32, M3, M5, S3, ALL SOLD but fondly remembered
      11-07-2007, 04:24 AM   #18
Bumps
Bumps's Avatar
Drives: E92 320i M Sport
Cheeky!! Cheeky - get it??? Ok
      11-07-2007, 04:54 AM   #19
BC4J
BC4J's Avatar
Drives: F30 328i
Someone said that this is actually used by BMW dealers, which implies it is recommended by BMW itself. Does anyone know if this is true? Blimey, it is expensive.
      11-07-2007, 05:03 AM   #20
Bumps
Bumps's Avatar
I've never heard of the stuff but I am a complete rattle obsessive (my wife thinks I am nuts)so I may well invest. Thanks for the tip Dazza
      11-19-2007, 05:25 PM   #21
jimlai322
jimlai322's Avatar
Drives: E60 535i & E90 325i
Anyone else has success with this product?
2008 SG E60 535i
2006 AW E90 325i
      11-20-2007, 01:42 AM   #22
BC4J
BC4J's Avatar
Drives: F30 328i
I did mention it to my dealer's service dept yesterday, said they never heard of it.
e90post
