FS: Hard Motorsport BBS Style Centerlock wheel set + adaptors (NEW)
01-10-2014, 11:49 AM | #1 |
Rep 134
~Two -18x8.5 ET40 with adaptors, centerlock nut, and 12.9 grade drive pegs/pins. Hub adaptors are for 5x120 PCD and 72.5 center bore. ~Two -18x9.5 ET35 with adaptors, centerlock nut, and 12.9 grade drive pegs/pins. Hub adaptors are for 5x120 PCD and 72.5 center bore Hard Motorsport STW Center Lock Hub adaptors simply bolt to your existing hub to convert to Center Lock Wheels. Brand new in original boxes! I ordered these and planned to install them for an ultimate centerlock wheel conversion but decided to go another route. I am also tossing in four (4) additional centerlock nuts ($400 value) anodized red for you to use as spares or to anodize a different color. *Note* Centerlock nut must be torqued to 350 ft/lbs. Hub-centric spacers can be used with the adaptors. This is a staggered setup so the rear face is more concave. Also, please research as to what size spacer you may need or whether or not these will fit your BMW. All I know is that the effective offsets (with centerlock adapter) for the front are ET40 and for the rear ET35. These can be fitted on BMW Z3 E36 E46 E90 E92 3-series including M3s but please verify offsets. $1600 - wheels are located in San Francisco. Spokes have machined inners, very much like high-end Motorsport wheels. How the adapter bolts up to your existing hub and secured by drive pegs. As fitted to E46 M3s (both are 18x9.5 squared) |
