F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > No dipstick
Studio RSR
      01-09-2014, 05:46 PM   #1
kent11202
Drives: 2013 328i
No dipstick
OK, so the 328i doesn't have a dipstick but there's a way to check your oil level without opening the hood. So, let's say you take your vehicle in for an oil change and the guy doing the job inadvertently puts in less oil than he should. Is there an "automatic" notification displayed on your instrument panel telling you the oil is low or do you have to continually monitor this on your own?
If there is an automatic display, how is the warrantee handled if the "trigger" device fails to notify you and you blow the engine due to lack of oil?
No problems at my end, just curious.
Full disclosure: I spent quite a few years as a mechanical designer and a design "checker" so I'm also looking at what could be the worst case scenario.
      01-09-2014, 05:49 PM   #2
OC40
Drives: 335i MSport + MPS/MPPK
2013 MINI S  [0.00]
2013 BMW 335i  [0.00]
You can moniter via iDrive.
      01-09-2014, 05:57 PM   #3
olinjohnston
olinjohnston's Avatar
Drives: 2014 428i & 1994 840Ci
Not only is the oil level monitored constantly, the functionality of the sensor itself is too...So if there is a fault with the measuring sensor, you will see a warning telling you to have it checked. The car will let you know to add a quart of oil before it gets to the absolute minimum, but you can check it periodically if you're the type who likes to keep it topped off. In addition to the convenience of checking the oil from the driver's seat more precisely than a dipstick, the oil level sensor will even warn you if it is overfilled.
Originally, I was critical of these systems too (at least without the backup of a mechanical dipstick) but they have proven to work well, promote more frequent checking of the oil, and are reasonably low-risk/reliable. If your fuel gauge fails to read accurately, for example, there is no such monitoring to warn you like the oil level sensor has.
Even still, the warranty would cover a replacement engine if it seized due to lack of oil caused by failure of the sensor AND the failure of the diagnostics of the sensor AND the fact that you would only be around a quart low by your next service visit anyway...point is: Don't worry about it.
      01-09-2014, 05:57 PM   #4
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25019
Drives: '22 Chalk Gray Porsche C2S
^^This!
[/end thread]
      01-09-2014, 06:14 PM   #5
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
But the bummer is I liked to do interim oil changes using an oil dipstick extractor. Awesome and clean way to go.
F30 Sapphire Black M-Sport 335i 6MT
      01-09-2014, 06:18 PM   #6
olinjohnston
Now you'll have to get familiar with the underside every once in awhile....Not a bad thing since you can check the condition of things down there, discover leaks early, etc.
      01-09-2014, 06:24 PM   #7
jadnashuanh
Drives: 535iGT x-drive; i3 BEV
It does take awhile after starting the car up for the oil sensor to register. Now, whether it might alert if it detected things low before it shows the actual level, I do not know. Mine has never seemed to go off of the full mark. I know some with V8's wished theirs did the same!
      01-09-2014, 06:38 PM   #8
kent11202
Drives: 2013 328i
Thanks Olin VERY helpful and informative. And thanks to OC40 and Sedan as well.
      01-09-2014, 06:39 PM   #9
olinjohnston
The V8 has two traditional turbochargers that pull oil into them for lubrication of the turbo and burn it off.
      01-09-2014, 07:56 PM   #10
BlauWeiss
Drives: F30 335i RWD
You guys are saying the oil level is monitored constantly.
A few days ago I "manually" checked the oil level on my 2012 335i using iDrive and it showed oil at "min". However, the car never notified me of anything automatically, today it shows all system as "OK". Does the car only notify the driver if the oil level drops below "min"? That doesn't make sense to me.
I scheduled an oil change (it was time anyway) for next week but am hesitant about driving it in the meantime.
      01-09-2014, 08:02 PM   #11
olinjohnston
Originally Posted by BlauWeiss View Post
You guys are saying the oil level is monitored constantly.A few days ago I "manually" checked the oil level on my 2012 335i using iDrive and it showed oil at "min". However, the car never notified me of anything automatically, today it shows all system as "OK". Does the car only notify the driver if the oil level drops below "min"? That doesn't make sense to me.
Any reading between MIN and MAX is considered normal operating range. If you are right on the minimum line, and your appointment is next week, there is no problem driving it until then.
      01-09-2014, 08:10 PM   #12
BlauWeiss
Thanks olinjohnston, appreciate the response. I won't worry about driving it a little based on your explanation and the fact that the car itself seems to think everything is OK.
Cheers.
      01-09-2014, 09:30 PM   #13
snowghost
snowghost's Avatar
That will take me back to old school days that started with my '69 VW Bug. The M-Sport looks like it needs ramps to get under there though.
      01-09-2014, 11:26 PM   #14
Elk
Drives: 2012 335i
A set of Rhino ramps, ten minutes and your oil is changed. Very easy on these cars.
      01-09-2014, 11:42 PM   #15
snowghost
snowghost's Avatar
Thanks for the tip!
      01-10-2014, 01:30 AM   #16
DanielBimmer
DanielBimmer's Avatar
106
Drives: YMB M4
I barley had oil left and my car got to the 250 degree mark and went into limp mode.. That's how I knew
      01-10-2014, 08:46 AM   #17
Axman85
Drives: 335i x-Drive M-Sport Min. Grey
My sensor had to be replaced. It constantly said I was low when in fact the car was full. The dealer knew something was wrong when 200 miles after a top off the sensor again said it was low. They drained the car to measure it and it was full. The part that troubles me the most is that before this episode the dealer topped me off twice in 5000 miles based on the sensor. I'm concerned that it was overfilled those two times.
Would rather have a dip stick. Sometimes the manual way is better.
      01-10-2014, 10:03 AM   #18
simongym
Drives: 2012 BMW 328i Sport
I agree, in that I wish they would include a dip stick as a manual way to verify. Sure the sensor is great as long as it's working correctly, but once or twice a year I'd love to be able to check with a dip stick to make sure the sensor hasn't unknowingly malfunctioned.
Electric-only systems will have limitations, even with certain good redundancies and checks that they have put in.
That being said I do enjoy being able to check the oil level from inside the car. I have it take a measurement 1-2 times a month, and it takes me two comfortable minutes after arriving at home or at work, very convenient.
Along these same lines, to me the TPMS is good and bad. It only alerts you with drastic pressure change, and you can only tell the actual pressure with a manual check. Maybe at some point they will add pressure readings, or even the ability to adjust and regulate the pressure internal to the car. Certain high-cost military and off-road vehicles have that kind of system, but it would be very useful on sports and luxury cars too.
      01-10-2014, 10:17 AM   #19
nyc2sd30
BMW Addict
nyc2sd30's Avatar
Drives: 2014 435i M Sport
You can get the pressure and temp reading coded to display on your iDrive.
2010 335i MSport / 2011 535i / 2014 435i M Sport
      01-10-2014, 11:03 AM   #20
snowghost
snowghost's Avatar
Yes it's very cool.
      01-10-2014, 11:47 AM   #21
simongym
Will a dealership do that, or is it a DIY?
      01-10-2014, 12:17 PM   #22
Frogman
Drives: 2012 F30 328i
DIY, see: http://www.f30post.com/forums/showthread.php?t=696777
f30post
