E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Lower control arms and bushes?
      01-09-2014, 10:37 AM   #1
muaythaimadness
Drives: E92 335d
Hi all,
i have an e92 335d m sport and recently have been noticing juddering under braking, more so when only lightly pressing the pedal. Sometimes it is more violent than others. At first i presumed it was warped discs, however when i got under the car i noticed that the brake reaction bushes are covered in what looks like oil/fluid residue.
Is this a common issue for e92's? Dont really want to pay to replace discs and pads on the front as these were done not that long ago so dont see how they are warped. Does anyone have any ideas to costs/work involved, and if I can just replace the bushes or would it need to be the whole arm?
Thanks
      01-09-2014, 11:24 AM   #2
phil200tdi
phil200tdi's Avatar
Drives: 335i M Sport E90 LCI manual
Get m3 arms
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft)
      01-09-2014, 01:12 PM   #3
muaythaimadness
Drives: E92 335d
thanks Phil. Is there anything else thats needed or are the arms a straight fit?
Any recommendations on where to look for them?
      01-09-2014, 03:15 PM   #4
tmarshall57
tmarshall57's Avatar
Drives: F10 530d M Sport, E87 118d M
Is the judder not more likely to be caused by something connected with the recent pad/disc change? Often the cause of judder is failure to clean (to spotless standards) the mating surfaces between disc and hub. A fragment of rust can cause significant judder - more noticeable under light braking.
F10 530d M Sport, September 2012 Individual Amazonite Silver, Oyster Dakota Leather, Auto, Nav Pro, Bluetooth + USB Devices, Expanded BMW Online, Comfort Seats, Sunroof, Sun Protection Glass Individual Satin Walnut Honey Brown Trim Interior Inside/Outside Mirror with folding and autodip, M Rear Spoiler
      01-10-2014, 01:39 AM   #5
phil200tdi
phil200tdi's Avatar
You'll need an alignment.
Look here:
http://www.e90post.com/forums/showthread.php?t=843644
      01-10-2014, 03:12 AM   #6
danb21t
Drives: Le Mans 335d M Sport
I have this exact same issue with my 335d.
I am going to have my car up in the air tomorrow for an inspection but so far I have put it down to uneven conditioning.
Whilst I have the wheels off I may pop the dial gauge on and see if there is in fact any run out.
There was a good page suggested in another thread with information around brakes..
http://www.stoptech.com/technical-su...nd-other-myths
      01-10-2014, 10:24 AM   #7
muaythaimadness
Drives: E92 335d
cheers for the advice, took the car to my mates today to look at (a bmw tech at my local dealers) discs are fine, did a run out test and no issues with them. Both bushes have failed (covered in hydraulic fluid) and there is a lot of play in both arms, especially around the ball joints. He also recommended the M3 arms so have got some of those on order for him to fit next week.
Fingers crossed that will sort it.
Thanks for the advice all!
      01-10-2014, 10:25 AM   #8
muaythaimadness
Drives: E92 335d
Look here:
cheers Phil, have got it booked in for a 4 wheel alignment once the new arms have been fitted
      01-10-2014, 02:08 PM   #9
phil200tdi
phil200tdi's Avatar
You'll need upper and lower arms as they are matching.
      01-11-2014, 10:29 AM   #10
danb21t
Well I had my car in the air this afternoon and checked the front brakes for run out.
There was a little bit but not excessive. I stripped it all down and cleaned up the mating surfaces. Less runout afterwards so fingers crossed.
I think my front bearings may be on the way out, but they look easy enough to change so will look at getting some replacements.
The upper control arms had a bit of movement when pull and pushed on, is this normal?area is the sum of all sides Undecided whether to replace them as a matter of course before my alignment/geo setup at WIM.
Does anyone know of a good place to get TRW parts??
      01-11-2014, 11:01 AM   #11
phil200tdi
phil200tdi's Avatar
Amazon is the cheapest - just slow.. I waited 4weeks.
I'm about to order the rear arms.
      01-12-2014, 10:14 AM   #12
danb21t
Looks like ebay may be the cheapest at the moment. I'm still on the look though...
      01-12-2014, 10:46 AM   #13
phil200tdi
phil200tdi's Avatar
Have you got a link to the eBay items?
      01-12-2014, 12:53 PM   #14
danb21t
Looks likes prices are around the £45 mark for non-m and around the £65 mark for m.
http://www.ebay.co.uk/itm/BMW-3-E90-...item3f264a6ef9
http://www.ebay.co.uk/itm/New-Trw-Tr...item5d469ca3ae
      01-15-2014, 02:05 PM   #15
muaythaimadness
Drives: E92 335d
New arms all fitted and made a huge difference to the handling of the car.
Had an issue when they did the alignment and tracking that the bolt for loss ending the track rod end snapped! So ended replacing both sides at the same time too
      01-15-2014, 04:03 PM   #16
danb21t
Did it eliminate the brake vibration?
      01-15-2014, 04:14 PM   #17
Josh1a1h
Drives: AzuriteBlack 335i E92
So which arms did you get.. M3 ones? And where did you get them from?
Has the vibration upon braking gone now?
      01-15-2014, 11:41 PM   #18
muaythaimadness
Drives: E92 335d
Got the ones on the link sent by Phil, yes the M3 ones.
Vibration all gone now, car feels a lot tighter and more responsive through steering.
      01-16-2014, 01:45 AM   #19
phil200tdi
phil200tdi's Avatar
My rear arms have just been dispatched. Bought via ebay.
      01-16-2014, 01:48 AM   #20
danb21t
Let me know how long they take to arrive please
      01-16-2014, 03:33 AM   #21
idnan
idnan's Avatar
England
76
Drives: Alpine White 335i
Which ones Phil? Only 3 out of the 5 rear arms fit the non-m models and one of them is exactly the same.
      01-16-2014, 07:25 AM   #22
phil200tdi
phil200tdi's Avatar
JTC1428 (Item 17)
JTC1429 (Item 17)
JTC1430 (Item 18)
JTC1431 (Item 18)
They should all fit and replace the standard items.
JTC1432 doesn't fit non M cars apparently (Item 13).
e90post
