01-03-2014, 02:37 PM | #1 |
Rep 30
Replacing a 2008 M3 E93 Battery
Like other prior posts, started to see my original OEM battery coming to the end of life (clock slow, odometer resetting).
Rather than pay a premium at a local BMW dealership, went the route of others and bought a similar spec'd battery to OEM. I also save on costs by installing it myself (see pictures for the install in the next post) and registered the battery at an independent BMW service shop. Battery: H8-AGM Duralast - http://www.autozone.com/autozone/par...9459_829936_0_ Retail $169.99 Paid $154.99 (returned my original battery so non $15.00 core charge and used this $15 coupon - http://click1.email.retailmenot.com/...rsqzqzpqp.html) Labor: Free – installed it myself (~30 minutes) Registration: $55 - http://www.eastsidebavarian.com/ (local BMW independent car service shop) Total Cost = $209.99 + WA tax |
01-03-2014, 02:54 PM | #2 |
Rep 30
Tools:
Gloves Flat Head Screw Driver 10MM Socket 13MM Socket Electrical or Painter's Tape Remove the initial cover by turning the highlighted screw. Remove the other covers by turning the screws and pulling the pieces. Unscrew the Negative terminal and wrap with tape. Unscrew the battery hold downs to give you room to move the battery to unhinge the top battery area. There is a 13MM bolt under the + symbol that will allow you to remove the red battery portion. Once set aside, you can unscrew the positive terminal. Remove the battery vent hose (note there may be traces of acid so it is important to be wearing gloves. Lift the original OEM battery by the handles (note it is heavy and easier to take it out from the side where you have more leverage and lifting area. What the area looks like when the battery is removed. Reverse the order and ensure you put the vent battery hose back into the positive portion of the battery. Also connect the positive terminal first and the negative terminal last. Go to a independent service shop to register your new battery. |
Theodore667.00 |
01-06-2014, 04:23 PM | #5 |
Rep 3,387
Good write up, OP. Next time, you'll be ready to code the reset yourself
http://www.e90post.com/forums/showthread.php?t=727091 |
01-12-2014, 04:35 PM | #6 |
Rep 5
I believe the OEM battery for the 2008 E93 vert is rated as 90 Ah / CCA 900. DuraCell and Duralast H8-AGM batteries are rated as 92 Ah / CCA 850.
Is it okay to put a replacement with a different rating? Can someone please clarify? P.S. Two BMW dealers in NJ mentioned that BMW recently has updated that the 92 Ah / CCA 850 is an acceptable rating. |
01-15-2014, 06:40 PM | #7 | |
Rep 30
01-16-2014, 10:16 AM | #8 | |
Putcha ang ganda...
279
Rep 5,441
when i got mine at sears its their AGM battery with 92ah / cca 950 i had to register it to be safe.. BMW recommend it and even local shops do... yes it will work without having to do it but im sure battery will not last long or might see issues in the long run. better to be safe than sorry.
01-20-2014, 03:33 PM | #9 |
Rep 5
Replaced with Duracell AGM (92 Ah / 900 CCA / Size: H8AGM)
Thanks guys!
Replaced the OEM battery (90 Ah / 900 CCA) made by Banner an Austrian company, with Duracell AGM (92 Ah / 850 CCA / Size: H8AGM / Group Size: 49). Bought it at Sam's Club for $159.95 + tax. Duracell is made in the USA, by East Penn. Comes with a 3 year Free Replacement Warranty and 8 year Pro-rated Warranty. My Indy installed the battery and registered it with the car for me... All is well now! P.S. Dealers wanted $325 + tax (minus 20% discount for CCA members) plus installation ($150 for 1 hour labor). OEM battery comes with only 2 year Pro-rated Warranty. Last edited by GoRoundel; 01-20-2014 at 03:44 PM.. |
10-16-2014, 04:22 PM | #10 |
So Kewl Guy
48
Rep 619
Question: if we change to a battery with 92ah and different cca, will bmwlogger be enough to register the battery with the change?
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
11-14-2015, 08:06 PM | #11 |
Rep 3
Ok so I'll just put my 2 cents on this older forum, I recently purchased a 2009 e93 and one thing that I have been noticing is the thing kept dying if I left the door open for less than 5 minutes, so I decided today to go get a new battery. I have a local indy I started using with this car and he is the best! He recently installed 2 new front control arms, a new leveller sensor and back plus alignment for $550! Anyways, I pulled apart the rear panels in the back and noticed my battery is :
S: 61 21 7 575 327 AW: 61 21 6 924 022 Which I have gathered is an AGM battery so I went over to my local autozone and bought the following: http://www.autozone.com/batteries-starting-and-charging/battery/duralast-platinum-battery/319459_0_0/ Was a perfect fit and was the same 900 CCA as the oem battery I was replacing, only difference is the autozone battery is 95 ah whereas the oam battery was 90 ah, hope that's not a problem. I went to the great indy I mentioned earlier and he registered for me for free! I tipped him of course and will definitely be using him in the future! Anyways, just wanted to share my story and hopefully help others going forward! |
10-20-2016, 10:56 AM | #13 |
Rep 1,320
10-20-2016, 11:33 AM | #14 |
Rep 101
If you change a brand new battery the system will detect it. No need to register
12-21-2016, 09:57 AM | #16 |
Rep 1,660
I just put a new battery in the car last night. Will I get a message soon saying it's noticed a new battery and ask me to register it? Drove in to work this morning, and nothing popped up 8/2012 build date. I had the car on a battery tender while replacing on hopes of keeping all stored data. Still ended up having to reset time.
Current: '13 E92 M3 Euro Delivery Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3 |
12-21-2016, 12:28 PM | #17 | |
Rep 303
01-17-2017, 10:43 AM | #18 |
Rep 7
Changed the battery and changed the VO to 90ah_agm and registered it. Quite a easy fix. Thanks for the awesome guide
10-17-2018, 09:22 PM | #19 |
Rep 959
Drives: 2012 E92 M3 DCT ZCP
Besides registering, are there any other reset procedures that need to be done when changing the battery? TIS makes it seem like there are some re-learning procedures that need to be done (auto engine start/stop, mount steering angle, etc.):
https://www.newtis.info/tisv2/a/en/e...system/2S8T2Cv Is it Ok to attach a trickle charger (like a CTEK) to the electrical leads under the hood to keep the settings while changing the battery?
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
