Need advice on Vishnu Exhaust
10-31-2007, 12:52 PM | #1 |
Rep 71
So, what's the general concensus on the Vishnu exhaust? Those of you who have had it installed, do you like it? Does it drone? Would you categorize it as agressive or more subtle? Any other thoughts?
10-31-2007, 02:31 PM | #2 |
Rep 1,954
Drives: 2020 X3M Competition
I like it... some people think it's a bit on the ricey side; but if you throw a magnaflow x-pipe in there it would sound a lot better imho.
11-02-2007, 07:29 PM | #5 |
Rep 270
I have and like mine. To each his own. It rumbles low at low RPM. Maybe a little high pitch at wider rpms, but tasteful. It compliments my Procede!!!!!!!!!!!!!!
11-03-2007, 10:11 AM | #6 |
Rep 507
I mounted 2 stainless supports between the pipes to reduce vibrations, and changed the rear mufflers to larger ones with an extra chamber to reduce sound
M3 E92 ESS VT-625
11-03-2007, 10:51 AM | #7 |
Rep 18,218
I have driven a customers coupe with this exhaust and I loved it. Not too loud, is fierce when you want it to be. I like a quieter exhaust so it may be too quiet for some.
11-04-2007, 09:33 PM | #8 |
Rep 2,558
Is Vishnu going to release a quad-tipped exhaust... thats what I'm looking out for...
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
11-06-2007, 07:59 AM | #10 |
Troll Harder
395
Rep 596
Drives: 997 GT3, 997 4 GTS, X6M
anyone have a sound bit of it?
11-06-2007, 08:45 AM | #11 |
Rep 18,218
Come on, thats what the is for! www.vishnutuning.com
11-08-2007, 03:00 AM | #12 |
Rep 2,740
Does it delete any cats or resonators? I am seriously confused deciding between this, the Borla catback, or Meisterschaft (all three sections).
In any case, I want to run DPs with exhaust eventually but I definitely need cats, preferably downstream from the DPs tho.
11-08-2007, 08:09 AM | #13 |
Rep 4,764
Vishnu deletes the rear cats (leaves the main cats since they are on the downpipe). Vishnu does not have an xpipe (balancing chamber), it is fully divorced. I have not heard it in person. I have the Britalman which also deletes the rear cats, but has a balancing chamber.
If you want a stock like mod, then go with a catback and high flow cat downpipes. The high flow cat downpipes allow you to just pull out the 02 sensors from the stock part and put them in the modified one. You really have to read about all the exhausts. Some are true bolt on, others need to cut the exisiting system. I know Britalman and Ultimate Racing are true bolt on. AA's needs to cut the existing exhaust. Vishnu does not mention, in their thread launching their exhaust, whether it is 100% bolt on, also does not say anything on their site. I would ask them to be sure. |
11-08-2007, 11:23 AM | #14 |
Rep 2,740
Thanks for the tip Scott -- by catback do you mean from the primary cats and back, or the secondary cats and back?
I'm not necessarily looking for a stock like exhaust... I'm really only trying to avoid an exhaust that drones and is obnoxiously loud and ricey. I know things will get loud with a catless DP and resonator delete (which I really want to do) so I want to gauge what is practical and feasible with this type of setup. I guess that's why I'm gravitating towards the systems that are reportedly quiet.
11-08-2007, 02:02 PM | #16 | |
Rep 4,764
When I say catback, I mean it replaces everything behind the downpipe(bolts on to the end of the downpipe), leaving the stock downpipe and main cats (that are on the downpipes) in place.
His comments started a whole debate about xpipes vs fully divorced systems. |
