FAO Makkan Mr Singh
12-27-2013, 04:08 PM | #1 |
Rep 4,261
FAO Makkan Mr Singh
Sam and Am
Happy holidays firstly. If I gave you £500 what could you do hifi wise to my car. I have a IB sub and Pheonix Gold amp [not wired in] and the standard shitty stereo. cheers
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
12-27-2013, 05:10 PM | #2 |
Rep 1,031
If you give me 500 quid I will sing in it for you. Sorry. Couldn't resist.
Happy holidays to you to sir.
E92 330D LCI
Garage List NSR 250 MC21, CBR 600RR 3 RVF400 |
12-27-2013, 05:26 PM | #3 | |
Rep 9,097
Or Save some money and then go for the Gladen deal (recently it was £600 for the drivers and mosconi 120.4 amp). Harness £40-50, amp wiring £30-40, sound insulation £20. You reach £700 for the kit only and that is after discount. Fit it yourself to save some money and get it tuned by somebody. or get both done by somebody. Remember tunning is essential part. Wrong tuning can destroy a decent kit, where as correct tuning can make a rubbish kit sound excellent. One example is Alpine retrofit kit (not that its rubbish). With 40W, it gives you decent sound as its already tuned! I have tuned few kits to name. Check with KAL 335D, Blondfella and IanS100. Apologies if my response disappoints you but audio upgrades are not easy and should not be done with limited budget especially on beamers.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
12-28-2013, 01:35 AM | #4 | |
Rep 81
I have the gladen dsp kit fitted and the range of adjustment is huge, having somebody set it up would be make a massive difference to the finished set up! |
12-28-2013, 05:21 AM | #5 | |
Rep 4,261
Cheers for the reply Sam. I like OEM idea of the Alpine kit but never heard one and not sure it will give me the kick in the back Im after. First thing I want to do is get my IB sub installed, so a Gladen harness 2 or 4 channel ? As long as I can add a amped front stage I will be happy.
12-28-2013, 06:35 AM | #6 |
Rep 42
Hi Sparky, I'm in Newmarket and have the alpine upgrade with my stereo coded to Wi-Fi (by Sam) if you want a listen. I'd recommend a different way rather than the Alpine retrofit.
Adam |
12-28-2013, 06:49 AM | #7 |
Rep 4,261
Thanks for the info Adam, think I am set on going aftermarket but stealth if that makes sense.
12-28-2013, 07:10 AM | #8 |
Rep 42
No probs, I wish I'd done that now. Don't get me wrong the Alpine upgrade is a huge improvement over the stock set up but you can get a awful lot more for your money by not going for the Alpine retrofit. I'm really tempted to go for the Gladen set up.
12-28-2013, 07:47 AM | #9 | |
Rep 5,050
After Sam had finished my Sat Nav upgrade he identified a lot of problems with the Mosconi/Gladen install / settings, and he spent quite a while sorting the mess left by the 'Professional' who had lightened my wallet by 'well over' £1k for the install. The difference Sam's changes made are phenomenal, it now sounds pretty much as I first expected it should, it doesn't hiss when it's switched off, no longer gives random pops and bangs and the rattle from the subs has all but disappeared. My experience has taught me that employing an established professional is not enough, recommendation means far more, which is why I was happy to drive 500 miles to have Sam upgrade the Sat Nav, and why I wish I'd asked him do the Mosconi/Gladen install as well - thanks again Sam Apart from the addition of the front tweeters in OE pods, and a couple of amps out of sight under the boot floor there is no way you'd know that the sound system has been modified. |
12-28-2013, 12:04 PM | #11 | |
Rep 81
Do you have the fronts and subs on the 120.4dsp or are you using that one for the front and rear now and have the subs on the non dsp 120.4? In any case you wouldn't like to share your settings would you? I don't suppose you would like to share your dsp settings would you |
12-28-2013, 12:15 PM | #12 |
Rep 4,261
Is Am banned?
12-28-2013, 12:53 PM | #13 | |
Rep 9,097
12-28-2013, 12:59 PM | #14 | |
Rep 9,097
If it helps, on Ian's car no coding tricks were used. On Blondfella's car, some coding tricks were used. On Kal's car some coding tricks were used. When I refer to tuning, I am only referring to adjusting input, gains and proper crossovers to start with. Coding comes afterwards and if you are 'vigilant' enough then all coding tricks are over the internet or at least there are clues for others. Nothing is 'behind the scenes'.
12-28-2013, 01:01 PM | #15 | |
Rep 9,097
Rears are run by 2 channel.
12-28-2013, 01:01 PM | #16 |
Rep 9,097
Send him a pm as he might be very busy around this time of the year.
12-28-2013, 01:05 PM | #17 | |
Rep 9,097
You approach should be opposite to find out if you really need IB after installing the sound system. IMHO, sound upgrade on BMW is 'necessity' where adding a sub to upgraded sound system is 'luxury'. Exception is, if you go for alpine retrofit kit where underseats should be upgraded or solo sub in the boot should be fitted. Which approach you take, totally depends on your, your resources and recommendations of your installer.
12-28-2013, 01:06 PM | #18 | |
Rep 5,050
Sure no prob, credit for the settings file should go to AndyRap who did the work but pm me your email & I'll send it over |
12-28-2013, 01:35 PM | #19 |
Rep 4,261
His profile says banned Sam.
12-28-2013, 01:39 PM | #20 | |
Rep 4,261
12-28-2013, 01:44 PM | #21 | |
Rep 81
12-28-2013, 01:53 PM | #22 | |
Rep 9,097
Thanks.
