BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      12-18-2013, 06:05 AM   #1
CDT
Drives: 2009 M3 E93 Convertible
My trials changing 2009 e93 M3 battery
Hello all! Let me be upfront, as I know this thread has some redundant/repeated information; however, my hope is to consolidate at least a small portion of that information (from other threads) so that you can learn from my trial(s), and errors (and ignorance in some cases). For those of you intent on making a superficial judgement re: reasonable people questioning unreasonable BMW parts costs and/or repairs (as I read on other threads related to this topic), please move on, you annoy me and provide no real value to BMW owners looking for helpful information. For those in need of some basic information, I sincerely hope this helps. I’ll try and be clear when I state “fact,” “opinion,” or “inferred” information where applicable. With that, I’ll crawl off my soap box now…
Background:
My 2009 e93 M3 recently experienced battery “issues” at 57,000 miles. It was slow to turn over, the clock began to lag several minutes behind over a few days, and an “Increased Emissions” light illuminated on start-up. Even in my limited knowledge, I began to suspect a battery in need of replacement- so I began to look into costs for a new one (and whine to myself that I was just 7k out of warranty). I’ve always been a subscriber to dealership service and parts, but their cost quote for a new battery was shocking to me, and caused me to question my blind allegiance.
As of 16 Dec, 2013, the information was presented as follows:
- Cost for a replacement battery by BMW of Concord: $498.20 + cost of registering battery to car computer. (Fact)
- Cost of registering battery by BMW of Concord: similar to BMW of San Francisco below (inferred through discussion w/service advisor)
- Cost of registering battery by BMW of San Francisco: $215.00 (Fact)
- Total cost for 2009 e93 M3 replacement battery: $713.20 (Seriously).
- “OEM” battery in car: Banner (Austria) brand, 900CCA, 90ah, 160RC battery, group size 49 (group size inferred from comparison to the Duralast I ended up replacing it with).
- Banner OEM battery for e93 M3 discontinued (fact, checked website and dealership), replaced with East Penn brand battery rated at 900CCA, 92ah, unknown RC (information was passed via phone call with dealership)
I was left to decide if I should use BMW, or pursue my own course of action. I decided on the latter. I did some “internet digging” (‘cause we all know the internet never lies!), and found there were several hundred battery manufacturers for automotive purposes; however, a few were repeated several times as they seem to be the major parent companies for a significant market share (opinion). Johnson Controls, Delphi, and Exide were named (though I learned Delphi was purchased by Johnson Controls). Douglas Battery, and East Penn were also named, more specifically in relation to BMW (East Penn often with the name Dekar if I’m not mistaken). FYI, East Penn manufactures West Marine batteries as well. But I digress…
Bottom line is, I ultimately decided I was not going to spend $700+ to replace a car battery. Here’s why. The East Penn battery that BMW is now using to replace OEM batteries in my vehicle cost $199.25 retail! Yes, I refuse to pay BMW $498.20 for a $199.25 battery. I don’t mind a slight markup. I don’t mind increased labor costs for BMW trained mechanics, but a mark-up in excess of 200% (and you know BMW doesn’t pay retail on the battery as we do). Are you F’N kidding me!!?
What I decided made sense:
First priority, match battery specifications,-with the most important being the following…battery type [Absorbed Glass Matt or “AGM” vs. flooded cell], Cold Cranking Amps (or CCA)- 900 in this case, Reserve Capacity (RC)- 160 (I exceeded this by using a battery with 170 RC), and group type (49 in this case).
There are several batteries that meet or exceed these specifications. I decided on a Duralast H8-AGM battery (made by Johnson Controls btw). Cost to me $169.99. It will be $184.99, unless you give them your old one (core) and get the $15.00 credit. I also received a 10% discount on top for being military. Next step was to have the battery “registered.” Registering and Coding have been discussed extensively on other posts by much more informed members than me. The way I understand it is this (dumbed down that is, I am a pilot after all)… Registering is required on my vehicle to tell the car’s computer that you have put a new battery in it, and it will reset the algorithm it uses to charge it over time (ie, it won’t attempt to work as hard to charge a fresh battery). Why BMW didn’t create a sensor that reads battery level and adjusts accordingly is for another discussion, but it should be readily obvious. If you fail to do this, it doesn’t mean your battery won’t work, but you will more than likely decrease the service life of your new battery, and I would guess a potential secondary effect to your alternator (opinion). Coding on the other hand (and this is where I’m drifting way out of my expertise) seems to relate to whether you change battery “types” (AGM vs flooded cell for instance). For the experts, please chime in. I apologize for including conjecture here.
I looked into shops capable of registering or coding. I received estimates ranging from $85-$215. Many of you have the tools necessary to do this yourself, or know a buddy in a shop that can do it for you. I paid $130.00 for an independent certified BMW shop to swap my battery and register it with factory BMW software. The final cost to me to replace my BMW battery was:
$183.11 (I didn’t give AutoZone my core) + $130.00 (register w/computer)= total cost of $313.11 + time. Total cost of BMW of Concord to replace my battery: $713.20. Total savings to me of $400.09 + PRINCIPLE.
Caveat: I’m not sure how this impacts e90/92 owners, in that I’m not sure if the e93 ‘vert has higher electrical demands…
For all, I hope this wasn’t “preachy”, that I posted this in the correct Forum, and that it helps even one person! Feel free to email me!
And I am deploying and selling aforementioned M3 (shameless plug) -------- No electrical issues!!!
Respectfully,
Clif
      12-18-2013, 07:40 AM   #2
the_road_less_traveled
Id rather be boating...
the_road_less_traveled's Avatar
Drives: Baja 26 Outlaw
Great information. This is the kind of material I like to read. ..factual unbiased detailed information. I'm in the same boat right now, but expenses are a little lower here in GA. Tischer sells the battery for about $220 shipped to me then I can take the battery and get $10 at any battery store for recycle and lastly I have an indy shop to register it for $47.50. Mind you I'm replacing and installing the batteries myself, but this is peanuts. I expect to have barley over $250 in an oem battery. Not bad compared to some of the other stories I've read about.
Thanks for sharing.
      12-18-2013, 07:52 AM   #3
didithepest
didithepest's Avatar
Drives: 2014 F10 550IX
2011 BMW E93  [0.00]
This is great information thank you for sharing .
      12-18-2013, 11:25 AM   #4
signes
signes's Avatar
Drives: 991 GT3 RS
Awesome post. Love the savings + PRINCIPLE, so true!
GT3 RS | Desperately seeking the next great M car...
      12-18-2013, 11:26 AM   #5
signes
signes's Avatar
Drives: 991 GT3 RS
BTW, where did you buy the battery?
      12-18-2013, 01:12 PM   #6
HPF_E92
Drives: E92
Thanks Clif for the great information, I am about to go through the same scenario!
      12-19-2013, 08:27 AM   #7
speedaddictM3
Drives: 2008 E90 M3
Background:
Respectfully,
Clif
Great thread. Came just in time, since my 5.5 year old battery is beginning to display mood swings and a mind of its own. I have the same OEM Banner battery as you do. The matching replacement from a nearby Canadian dealer was $360 just for the part, without any labor or registration included. I'd imagine it will cost me more than $500 out the door.
As for battery registration, it's simple. You can download free BMWLogger on a laptop, and buy a K+DCAN cable and do it yourself. The One Stop Electronics cable is about $100. Don't buy the cheapo $20-$35 cables off eBay. I bought one and it failed after using it about a dozen times or so I now have the One Stop Electronics cable on order.
You can also do the coding yourself if you change battery specs also using free software and the cable, but it's a bit more technical and involved. I have no idea how to do it so I'll stick with a battery matching OEM specs.
      12-20-2013, 11:29 AM   #8
speedaddictM3
Drives: 2008 E90 M3
I just got my new battery yesterday for just $185 CAD on sale from Crappy Tire. It was MotoMaster Eliminator Ultra Flat Plate AGM Automotive Battery Groul L5/49 which is just a rebranded Exide Edge AGM Car Battery (Group L5/49). Matches OEM specs and cost me HALF what the bmw stealership wanted. And I'll install and register it myself, so I save myself the labor costs too.
      12-21-2013, 11:42 AM   #9
SilentAttack
SilentAttack's Avatar
163
Drives: 08 E90 Jerez Black 6MT
Great info. Im sure I will be in this boat soon
Stupid Photobucket
      12-23-2013, 02:37 AM   #10
CDT
Autozone
I ended up buying mine at Autozone. Sears has a battery with almost identical specs (surprise I know since Johnson Controls makes them both!) as well. If I wasn't pressed for time, I probably would've made the 45min trip to buy the East Penn replacement in San Jose.
      12-23-2013, 02:39 AM   #11
CDT
Thanks!
I really appreciate the info. Hopefully others can follow your advice and save a few hard earned $!
      12-28-2013, 07:30 AM   #12
E30_80Y
Still love my E30
E30_80Y's Avatar
Drives: E30S52+E90M
Where is the "like" button! Lol great info OP! Will be needing it soon. Thanks
http://www.m3post.com/forums/attachment.php?attachmentid=639065&stc=1&d=1328218  081
E90 sparkling graphite-borla exhaust-arkym carbon fiber front lip-gloss black kidney grills-rd sport springs-19" iss forged fm-10
      12-29-2013, 03:39 PM   #13
ReD-DaWg-OnE
Drives: '09 E90 M3
Thanks! Just what I was looking for!
      01-01-2014, 06:34 PM   #14
coriolis14
Drives: 2007 E92 328i
My Saving Grace (maybe)!
This thread might just be my saving grace in my search for a battery replacement!
I'm currently trying to find a replacement battery for my '07 E92 328i and came across this thread while searching forums around the web. I know I don't have either an E93 or an M3, but after I did some digging I found out that my battery is unusual for a 328i to have (it has 90Ah/900CCA in a hardtop configuration). I've been searching for almost 2 weeks now for someone else who has a battery with similar output to mine with no avail - all other 328s from my model year either have a battery with 570CCA or 720CCA. Also my battery part number isn't listed for a 328i on RealOEM's webpage when I went searching for an OEM replacement.
CDT (or anyone else who followed in his/her footsteps), I would like to follow the route you went in replacing your old battery. I think the original battery in your E93 M3 is similar to the one in my E92 and was hoping you could confirm that with me before I purchase a new battery.
Pic of my battery's specs:
View post on imgur.com
Link for RealOEM's webpage: http://www.realoem.com/bmw/showparts...99&hg=61&fg=30
Thanks for your time and Happy New Year everyone!
Last edited by coriolis14; 01-01-2014 at 06:41 PM.. Reason: clarifying my thoughts
      01-03-2014, 07:51 AM   #15
CDT
Replacement battery
Honestly my friend, as long as you replace the battery with a like type (AGM vs Flooded Cell), size, and CCA, you should be fine. That's ultimately what I was trying to convey....replace your OEM with a battery with similar specs. You can call down to your local dealer, find out the OEM battery, and pay someone (or have a friend) to register your battery to your car, once it's installed.That is, if you don't want to go the ultimate "discount way!"
You will, in the end, have an OEM battery and save a couple hundred dollars. All the best!
      01-05-2014, 12:27 PM   #16
C|3R1C
So Kewl Guy
C|3R1C's Avatar
49
Drives: 2010 E93 M3 DCT
This is very helpful! Thank you OP!
Just a quick question: I was looking at the specs for the H8-AGM from duralast (on the autozone website), and the CCA is 850. Does that really make a difference?
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
      01-23-2014, 05:42 AM   #17
CDT
Not sure if you were looking at the most current model...? My H8-AGM exceeded 900CCA to my knowledge. Realistically, I doubt it would make much difference with a -50CCA differential however, I would personally strive to match or exceed the OEM specs just to be on the safe side. My 2 cents only.
      01-23-2014, 12:07 PM   #18
marksae
marksae's Avatar
36
Drives: ///M
I recently changed my 90ah 900CCA battery with a Sears Diehard 92ah 850CCA battery. It's been fine. I don't notice a difference. But my car is always garaged and I live in CA. So my car doesn't experience the extreme cold start conditions.
Anyway, I already had the One Stop Electronics cable. So I d/l'd the free version of BMW Logger and registered the battery. It was a cinch. Took 2 minutes. The dealers must make a killing on these battery registrations.
04 E46 M3 6MT - AW / Cinn
93 FD RX-7 Base Manual - BB / Blk
IG: @gearheadtwins
      02-07-2014, 08:37 AM   #19
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
I bought my AGM diehard battery at sears for 145 was on sale... then registered mine at EAS... way so much cheaper than the dealer. so if your in SOCAL and want to register your battery i suggest to CALL EAS...
majority of the MY08 replaced theirs early last year or 2 years ago... MY09 should be coming up anytime soon...
      09-12-2014, 10:56 AM   #20
TMiller
TMiller's Avatar
Drives: e92 Frozen Silver Edition
Older post, I know, but just wanted to express my thanks to the OP for a helpful and thoughtfully worded post. Just what I needed to know.
2012 Frozen Silver Edition | Evolve stage II
      10-28-2015, 05:09 PM   #21
boostincincy
Drives: E92, E36 M3 race car, 19' X5
Going through this now with my 08 E92, bless you OP
      02-16-2016, 10:31 PM   #22
Darkmoyle
Darkmoyle's Avatar
Drives: 2008 E90 M3
Good info at the top of this post so I felt I should add to it with some up to date info.
My 08 E90 M3 car has had an easy life in northern California so when the car started giving the low battery symbol on the dash I knew it was time to change the ORIGINAL '08 BMW battery. After researching the forums I went with an Exide FP-AGML5/49. I rang my northern CA distributor and they directed me to my local garage; European Sports Cars Garage Inc., Sacramento, CA. They sold me the battery for $165 plus tax less mail in rebate of $20. So after giving them my core I got a CCA850 RC160 battery for $149. They advised me to get the battery coded/registered within a month. They can do it for $80 but I think I will buy the cable (K + CAN) and try to do it myself. The same battery was in homedepot for 245+ tax and carid.com for 220 inc delivery.
m3post
