E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Xtreme 6000k D1S Low beam bulb upgrade & Xtreme H11 6500k Fog light HID upgrade
      10-29-2007, 12:32 PM   #1
JayML
Drives: ....
I was able to get a set of these D1S 6000k bulbs from Steve at Xenondepot (new site is www.KBcarstuff.com) to try and and give a review. The bulbs are made in Japan and are designed to be a plug+play upgrade for our vehicle. I also upgraded my OEM fogs to HID with their Xtreme 6500k. I was a little worried that installing this kit will trigger a fault however Steve let me try out a new kit that that is designed specifically for CANBUS vehicles. NO ERROR CODE or flashing occurred! This kit works!
Here are some pics/review:
Xtreme 6000k D1S bulbs:
Installation was very easy and did not require ANY modifications to the vehicle. The Xtreme 6000k D1S bulbs plugged right in! The color is pure white with just the slightest touch of blue/purple. They look much better than the stockers, which I think looks slightly yellow.
Before/After:
The thing that surprised me the most is the light output. When it comes to colour temperature, the higer in terms of color/kelvin, the less output/lumens you get. These bulbs seem to be no exception but the loss here seems to be very, very minor. I've put 6000K ultinon bulbs in previous cars and the loss in output was much more noticeable than these. As I get older, I tend to stay away from mods that might compromise safety. I have no reservations on this mod as again, loss in ouput was negligible. In some aspect, I actually feel that the colour these bulbs emit help me see better at night as they light up the road with a slightly "more crisp" colour.
I'm very happy with these bulbs. They provide me with just the colour and brightness that I was looking for. If you're looking for higher K bulbs and do not want to compromise light output, these bulbs will do just that!
H11 6500k Xtreme HID Fog Light Upgrade:
To start off, I would like to say that I was very concerned about installing a kit in the fogs in fear of the dreaded CANBUS. Steve let me try out a new kit that is specifically designed for these applications that will not trigger a fault. I was a little weary as I've read reviews where people tried "special kits" however still got the error code. However, based on my past experience with XenonDepot and their reputation I decided to give it a try. To sum it up in 2 words - IT WORKS! No error messages, no flashing lights, Im happy.
The kit comes with a special adaptor that is able to trick the CANBUS system into not throwing a code:
I have seen many kits that use similar looking components. However, what I liked about this kit was that the casing was completely sealed and water tight. This is important as the ballasts are mounted low where they will be exposed to water/moisture. The ballasts themselves are completely sealed as well (epoxy sealed) which made me comfortable as well knowing that they are mounted low as well. The rebased H11 bulbs plugged right into the stock fog light assembly with no modifications. The ballasts pluggred right into the vehicle's OEM H11 fog light harness with a proper H11 mating connector. There was no wire splicing/cutting required. Everything was literally plug+Play and water tight. Here is the result:
To end off, I would like to say thank you to Steve at XenonDepot. I highly recommend this company for anyone that is looking for lighting upgrades. Their products are not always the cheapest, but most imortantly you are getting quality products with after sales service/support.
Here are the links to the products I used:
Xtreme D1S 6000k bulbs:
http://www.kbcarstuff.com/Xtreme_HID.../xt-d1s-6k.htm
H11 6500k HID Conversion kit:
http://www.kbcarstuff.com/H11_6500k_...xt-65k-h11.htm
CANBUS Fix (H11 option selected):
http://www.kbcarstuff.com/CANBUS_Fix_p/cbfix.htm
Note - All pictures were taken once the bulbs were fully warmed up.
      10-29-2007, 03:17 PM   #2
Andrew@ET
Drives: Red thing
100 each ..
      10-29-2007, 03:56 PM   #3
jetblk328i
jetblk328i's Avatar
309
Drives: X3 M40i
hmm the osram oem are at 4100K i thought 4300K
      10-29-2007, 05:14 PM   #4
cedchung
Mauritius
64
Drives: 2011 F25, 2014 F30
nice! finally a fix for the fog lights error messages.
      10-29-2007, 08:51 PM   #5
Cis
Drives: 07 Jet Black 335i
these work for e92 too correct?
      10-30-2007, 02:49 AM   #6
big pimp
big pimp's Avatar
Drives: G05 M50d & Dakar Yellow E46 M3
great.... but $100 per bulb is taking the pi$$ a bit....
      10-30-2007, 05:39 PM   #7
shaiiE90
B!MM3R06
shaiiE90's Avatar
Drives: 2006 BMW 330xi
Angry HID/fog lights
ok i have a question about an install i just did on my car. i have a E90, i just installed hid's in my fog lights, the problem i'm having is the lights turn on fine but after a few seconds they start to flicker on and off. does anyone or has anyone had this problem if so wha t can be done?
i know this might be on the subject but i had nowhere esle to post this, i'm sorry if i'm wasting anyones time.
      11-06-2007, 10:52 PM   #8
nyc3r
nyc3r's Avatar
Drives: E90
Can anyone else confirm the Xtreme H11 HID kit are error free in E90... no flicker... with engine running..
      11-07-2007, 12:16 AM   #9
BMW_TT
Drives: E92 335i
is it just me or do those have a blue tint to them
      11-07-2007, 12:56 AM   #10
youyou
youyou's Avatar
Drives: Porsche 997 C4S
Thats what i really like about them...
I'm looking to get that blue tint without having to go too blue with a 8000k.
But there's so many brands i really don't know which ones to go for
      11-10-2007, 09:51 PM   #11
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Mine's still on back order a week after they came back from SEMA. I want to test this out before I send my broken but working UED kit back
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      11-11-2007, 08:53 AM   #12
edy74
edy74's Avatar
Romania
133
Drives: CUSTO///M E90 , 640d xdrive
2006 318i  [9.00]
will this 'CANABUS fix' kit work on Mtech fogs?
      11-11-2007, 10:14 AM   #13
BoostedBMW
BoostedBMW's Avatar
Drives: TiAg E92 335
2003 S2000  [0.00]
I love the look of the fogs. Its nice to see that they are completely plug and play.
-Michael.
Berlina Black S2000 CR is now in the garage
l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l
      11-13-2007, 10:42 AM   #14
JayML
Drives: ....
Its been several weeks and the lows and fogs are still working flawlessley =) No flickering!
      11-13-2007, 12:16 PM   #15
edy74
edy74's Avatar
Romania
133
2006 318i  [9.00]
NO ERROR MSG? my Mtec Hid's start showing the ERROR MSG after a month ....... Do U kno if this "special adaptor that is able to trick the CANBUS system into not throwing a code", work on Mtech fogs? THX
      11-13-2007, 04:36 PM   #16
shaiiE90
B!MM3R06
shaiiE90's Avatar
i got the flickering fix on the HID fog lights. theres a secton part that needs to be plugged in or wired in with the install
      11-21-2007, 12:45 PM   #17
JayML
Drives: ....
My flicker fix plugged right in.
      11-21-2007, 06:18 PM   #18
edy74
edy74's Avatar
Romania
133
2006 318i  [9.00]
Any help? PLEASE
      11-27-2007, 11:29 PM   #19
Flea7
Flea7's Avatar
Drives: E92 M3 6MT/F48 X1/F430/F12
2016 X1  [0.00]
2008 E92 M3  [0.00]
2005 Ferrari F430  [0.00]
2014 Ferrari F12 Be ...  [10.00]
I bought a set of rebased Philips H1 6000k kit from steve @ xenondepot back in 2002! Great customer service! ...and guess what?..... My kit is still going strong!
Oh, and back then I think I paid close to $500 for the kit so the prices now are very cheap!
      11-27-2007, 11:34 PM   #20
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
not enough power.......you need a harness with relay to connect directly to the battery.
i had the same problem with my HID fog kit....the harness with relay got rid of the flickering then off problem.
but the "ERROR" code remained......so i dumped it.
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
      11-27-2007, 11:37 PM   #21
Flea7
Flea7's Avatar
2016 X1  [0.00]
2008 E92 M3  [0.00]
Make sure you have a solid ground.
      11-28-2007, 01:40 PM   #22
dnjc
Drives: Diesel :)
ok, I'm going to be picking up the Xtreme 6000K bulbs to replace my OEMs...does Xenondepot/KBcarsstuff offer 6000K fog light bulbs (non-Xenon)? I just want to get some bulbs to replace my current ones and not deal with any error codes
Dan
e90post
