E9X M3 Side Mirrors Black
11-29-2013, 01:33 PM | #1 |
Rep 10
E9x M3 side mirrors black base with black caps in very good condition. These will fit 3 series and 1 series BMW's. There power folding, auto dimming, and headed they have been tested and everything is working properly. these mirrors go for over $2000 each new. Below is link for ad with pics. price $1200 for set http://toronto.kijiji.ca/c-cars-vehi...AdIdZ548114326 Text me for info 416 669 5858 |
11-29-2013, 01:56 PM | #2 |
BimmerPost Supporting Vendor
2111
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
Just FYI M3 sedan mirrors don't fit coupes, and viceversa.
Give us the product #. It will be e90/e91 OR e92.
11-29-2013, 08:09 PM | #6 | |
Rep 166
The preceding posts answers your questions:
11-30-2013, 01:27 AM | #8 |
Rep 696
Drives: 2012 E70 X5
these are E92 mirrors everyone
2011 BSM 335i E90 MTECH 6MT JB4 stage 2 iso 5.3 FF wire BMS Intake Vishnu DP Cyba Scoops LUX V4 6000K Headlight/Fog light Philips Ultinon Euro headlight switch ACS roof wing 35% tint Performance Grilles Misc coding Cobb charge pipe ///M3 fenders 335is pedals BC Coilovers Vrsf 7" IC ///M3 mirrors
11-30-2013, 04:45 PM | #9 |
Rep 192
I am very interested. Is this a plug and play for an e92 LCI 335i? Also, I don't have the power folding function on my car. Will this affect the plug and play? Thanks much.
How much would it cost to ship to USA, zip code 92677? |
11-30-2013, 08:20 PM | #10 |
Rep 607
Need codify ...... and taste !!
12-01-2013, 02:53 PM | #12 |
No 55mph
1622
Rep 8,476
Well, if you don't have power folding, and want to retrofit power folding - it's more involved than just coding.
You would need the entire DS Window switch that has the Power Fold Switch in it, DS door wiring harness, PS Door wiring harness, and you would have to run some custom wires from DS door, under dash, to control module under dash DS. Then you would have to code for Power Fold. To code you either need to have someone do it for you, or buy the special cable, download the INPA/NCSExpert software and learn how to code - then follow the directions given (See coding section of forum for direction-you will have a lot of reading to do ) Do 'Search' on forum for 'Power Fold Mirror Retrofit' for in depth explanation & instructions... Since these are also Auto Dim - if you don't currently have Auto Dim - then that function would need to be coded also. You will need to have the correct wiring harness with the same amount of connectors in the plug to match the connector on the mirrors - some have (3), some have (5) So if you currently have Heated/Power Fold/Auto Dim mirrors - these would be PnP on an E92, otherwise it is alot more involved. People need to do in depth research on retrofits before they hurry up & buy - not much is PnP with BMW if your car did not originally come with that option.
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
12-01-2013, 08:01 PM | #13 | |
Rep 607
I installed on a E91/2006 without bus-line.......good work !!
